[postgis-users] configure: error: GDAL Python bindings required by raster2pgsql.py loader
William Kyngesburye
woklist at kyngchaos.com
Tue Oct 18 09:07:05 PDT 2011
While your GDAL was compiled for a newer numpy, probably in MacPorts, it's probably not overriding the numpy in the system (the older one I assume).
A standard numpy install uses the normal python path loading order, and in Apple's infinite wisdom (to keep an incompatible version from overriding what's in the system, I guess) the user site-packages (/Library/Python/x.y/site-packages, including any .pth files in there) is searched *after* system packages. You need a custom .pth file that prepends (insert) the numpy path to the sys.path (I do that for my numpy package).
On Oct 18, 2011, at 10:50 AM, Puneet Kishor wrote:
> On Oct 18, 2011, at 8:28 AM, William Kyngesburye wrote:
>> I don't think GDALFPolygonize is the problem, that's just a test for a new feature in development GDAL and it's OK if it fails. After that should be the "checking for GDAL Python bindings" info.
> Gah! Dunno what I did, but now GDAL Python bindings are discovered, but seems like I have the wrong version of something.
> RASTER: Raster support requested
> checking for GDAL >= 1.6.0... found
> checking for GDALFPolygonize in -lgdal... no
> checking for GDAL Python bindings... found
> checking for NumPy array support in GDAL Python bindings... RuntimeError: module compiled against API version 6 but this version of numpy is 4
> not found
> configure: error: GDAL Python bindings with NumPy array support required by raster2pgsql.py loader
> I am not sure above what is compiled against API version 6 of what and what is the "this numpy" with version 4. Fwiw
> punkish at mumbai ~$/opt/local/bin/python2.7
> Python 2.7.2 (default, Sep 13 2011, 14:07:58)
> [GCC 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2335.15.00)] on darwin
> Type "help", "copyright", "credits" or "license" for more information.
>>>> import numpy as np
>>>> np.__version__
> '1.6.1'
> Puneet Kishor
> postgis-users mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
