[postgis-users] compile on solaris 11 sparc
Chris Hermansen
chris.hermansen at tecogroup.ca
Mon Sep 5 08:06:24 PDT 2011
Please pardon my ignorance of all things windows but is the cpp not one of
those universal components of the c programming environment?
(apologies in advance I know.this is not a postgis question)
On Sep 5, 2011 4:51 AM, "Mark Cave-Ayland" <mark.cave-ayland at siriusit.co.uk>
wrote:
> On 02/09/11 18:02, Doug McComber wrote:
>> I've got this in my profile:
>> # 64 bit compiling
>> CC="gcc"
>> CXX="g++"
>> CPP="gcc"
>> CFLAGS="-m64"
>> CPPFLAGS="-m64"
>> CXXFLAGS="-m64"
>> # 3rd party libray
>> LDFLAGS="-L/usr/local/lib"
>> and ran source ~/.profile
>> Despite that I found I had to add some of that to the configure command
>> (shouldn't have to log out after sourcing profile right?) like so:
>> ./configure CC=gcc CFLAGS=-m64 CPPFLAGS=-m64 CXXFLAGS=-m64
>> LDFLAGS=-L/usr/local/lib --with-geosconfig=/usr/local/bin/geos-config
>> This completes without error. The only warnings I saw were about dblatex
>> and CUnit. The final output of configure being:
>> PostGIS is now configured for sparc-sun-solaris2.11
>> -------------- Compiler Info -------------
>> C compiler: gcc -m64
>> C++ compiler: g++ -m64
>> -------------- Dependencies --------------
>> GEOS config: /usr/local/bin/geos-config
>> GEOS version: 3.3.0
>> PostgreSQL config: /usr/postgres/9.0-pgdg/bin/64/pg_config
>> PostgreSQL version: PostgreSQL 9.0.4
>> PROJ4 version: 47
>> Libxml2 config: /usr/bin/xml2-config
>> Libxml2 version: 2.7.6
>> PostGIS debug level: 0
>> -------- Documentation Generation --------
>> xsltproc: /usr/bin/xsltproc
>> xsl style sheets:
>> dblatex:
>> convert: /usr/bin/convert
>> Make starts out well but dies with an error complaining about not
>> finding SunStudio!
>> gcc -m64 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o g_util.o g_util.c
>> gcc -m64 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o lwgeodetic.o
>> lwgeodetic.c
>> gcc -m64 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o lwtree.o lwtree.c
>> gcc -m64 -fPIC -DPIC -Wall -Wmissing-prototypes -ffloat-store -c -o
>> lwspheroid.o lwspheroid.c
>> ar rs liblwgeom.a measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o
>> lwpoint.o lwline.o lwpoly.o lwmpoint.o lwmline.o lwmpoly.o
>> lwcollection.o lwcircstring.o lwcompound.o lwcurvepoly.o lwmcurve.o
>> lwmsurface.o lwutil.o lwalgorithm.o lwgunparse.o lwgparse.o
>> lwsegmentize.o wktparse.tab.o lex.yy.o vsprintf.o g_box.o g_coord.o
>> g_geometry.o g_ptarray.o g_serialized.o g_util.o lwgeodetic.o lwtree.o
>> lwspheroid.o
>> ar: creating liblwgeom.a
>> make[1]: Leaving directory `/home/doug/sources/postgis-1.5.3/liblwgeom'
>> make -C postgis
>> make[1]: Entering directory `/home/doug/sources/postgis-1.5.3/postgis'
>> /opt/studio11/SUNWspro/bin/cc -Xa -E -traditional-cpp postgis.sql.in.c |
>> grep -v '^#' > postgis.sql.in
>> /bin/sh: line 1: /opt/studio11/SUNWspro/bin/cc: not found
>> make[1]: *** [postgis.sql.in] Error 1
>> make[1]: *** Deleting file `postgis.sql.in'
>> make[1]: Leaving directory `/home/doug/sources/postgis-1.5.3/postgis'
>> make: *** [postgis] Error 2
>> This is a Solaris 11 box I should mention and gcc was installed from the
>> Oracle Solaris 11 repository as opposed to a 3rd-party package or from
>> source. I don't have Sun Studio installed (never did) and other programs
>> compiled without problem (Proj 4 and GEOS). This error
>> "/opt/studio11/SUNWspro/bin/cc: not found" appears to be PostGIS
>> specific (according to Google anyway). Suggestions?
> Right, so currently the .sql files are generated using the C
> pre-processor and so uses the CPP variable in addition to the ones
> defined above. I'm not sure what the correct command line should be to
> invoke the pre-processor in Sun's compiler is though.
> I think we need to start thinking about ripping the CPP code out and
> finding something more suitable instead, particularly when thinking
> about building other platforms such as Win32/64. I'm not exactly sure
> what the replacement should be though :/
> ATB,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> Sirius Labs: http://www.siriusit.co.uk/labs
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110905/cc32fc6a/attachment.html>
