[postgis-users] compile on solaris 11 sparc
Paul Ramsey
pramsey at opengeo.org
Mon Sep 5 16:51:57 PDT 2011
Yeah, I was going to ask a similar question: we want a tool that does
everything cpp does (replacements, inclusions, conditions), but isn't
cpp?
P.
On Mon, Sep 5, 2011 at 8:06 AM, Chris Hermansen
<chris.hermansen at tecogroup.ca> wrote:
> Please pardon my ignorance of all things windows but is the cpp not one of
> those universal components of the c programming environment?
> (apologies in advance I know.this is not a postgis question)
> On Sep 5, 2011 4:51 AM, "Mark Cave-Ayland" <mark.cave-ayland at siriusit.co.uk>
> wrote:
>> On 02/09/11 18:02, Doug McComber wrote:
>>> I've got this in my profile:
>>> # 64 bit compiling
>>> CC="gcc"
>>> CXX="g++"
>>> CPP="gcc"
>>> CFLAGS="-m64"
>>> CPPFLAGS="-m64"
>>> CXXFLAGS="-m64"
>>> # 3rd party libray
>>> LDFLAGS="-L/usr/local/lib"
>>> and ran source ~/.profile
>>> Despite that I found I had to add some of that to the configure command
>>> (shouldn't have to log out after sourcing profile right?) like so:
>>> ./configure CC=gcc CFLAGS=-m64 CPPFLAGS=-m64 CXXFLAGS=-m64
>>> LDFLAGS=-L/usr/local/lib --with-geosconfig=/usr/local/bin/geos-config
>>> This completes without error. The only warnings I saw were about dblatex
>>> and CUnit. The final output of configure being:
>>> PostGIS is now configured for sparc-sun-solaris2.11
>>> -------------- Compiler Info -------------
>>> C compiler: gcc -m64
>>> C++ compiler: g++ -m64
>>> -------------- Dependencies --------------
>>> GEOS config: /usr/local/bin/geos-config
>>> GEOS version: 3.3.0
>>> PostgreSQL config: /usr/postgres/9.0-pgdg/bin/64/pg_config
>>> PostgreSQL version: PostgreSQL 9.0.4
>>> PROJ4 version: 47
>>> Libxml2 config: /usr/bin/xml2-config
>>> Libxml2 version: 2.7.6
>>> PostGIS debug level: 0
>>> -------- Documentation Generation --------
>>> xsltproc: /usr/bin/xsltproc
>>> xsl style sheets:
>>> dblatex:
>>> convert: /usr/bin/convert
>>> Make starts out well but dies with an error complaining about not
>>> finding SunStudio!
>>> gcc -m64 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o g_util.o g_util.c
>>> gcc -m64 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o lwgeodetic.o
>>> lwgeodetic.c
>>> gcc -m64 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o lwtree.o lwtree.c
>>> gcc -m64 -fPIC -DPIC -Wall -Wmissing-prototypes -ffloat-store -c -o
>>> lwspheroid.o lwspheroid.c
>>> ar rs liblwgeom.a measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o
>>> lwpoint.o lwline.o lwpoly.o lwmpoint.o lwmline.o lwmpoly.o
>>> lwcollection.o lwcircstring.o lwcompound.o lwcurvepoly.o lwmcurve.o
>>> lwmsurface.o lwutil.o lwalgorithm.o lwgunparse.o lwgparse.o
>>> lwsegmentize.o wktparse.tab.o lex.yy.o vsprintf.o g_box.o g_coord.o
>>> g_geometry.o g_ptarray.o g_serialized.o g_util.o lwgeodetic.o lwtree.o
>>> lwspheroid.o
>>> ar: creating liblwgeom.a
>>> make[1]: Leaving directory `/home/doug/sources/postgis-1.5.3/liblwgeom'
>>> make -C postgis
>>> make[1]: Entering directory `/home/doug/sources/postgis-1.5.3/postgis'
>>> /opt/studio11/SUNWspro/bin/cc -Xa -E -traditional-cpp postgis.sql.in.c |
>>> grep -v '^#' > postgis.sql.in
>>> /bin/sh: line 1: /opt/studio11/SUNWspro/bin/cc: not found
>>> make[1]: *** [postgis.sql.in] Error 1
>>> make[1]: *** Deleting file `postgis.sql.in'
>>> make[1]: Leaving directory `/home/doug/sources/postgis-1.5.3/postgis'
>>> make: *** [postgis] Error 2
>>> This is a Solaris 11 box I should mention and gcc was installed from the
>>> Oracle Solaris 11 repository as opposed to a 3rd-party package or from
>>> source. I don't have Sun Studio installed (never did) and other programs
>>> compiled without problem (Proj 4 and GEOS). This error
>>> "/opt/studio11/SUNWspro/bin/cc: not found" appears to be PostGIS
>>> specific (according to Google anyway). Suggestions?
>> Right, so currently the .sql files are generated using the C
>> pre-processor and so uses the CPP variable in addition to the ones
>> defined above. I'm not sure what the correct command line should be to
>> invoke the pre-processor in Sun's compiler is though.
>> I think we need to start thinking about ripping the CPP code out and
>> finding something more suitable instead, particularly when thinking
>> about building other platforms such as Win32/64. I'm not exactly sure
>> what the replacement should be though :/
>> ATB,
>> Mark.
>> Mark Cave-Ayland - Senior Technical Architect
>> PostgreSQL - PostGIS
>> Sirius Corporation plc - control through freedom
>> http://www.siriusit.co.uk
>> t: +44 870 608 0063
>> Sirius Labs: http://www.siriusit.co.uk/labs
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
