[postgis-users] Question about st_difference
    Chris Hermansen
    chris.hermansen at tecogroup.ca
    Wed Sep  7 11:39:36 PDT 2011
In addition to Nicolas' suggestion, one thing that can work, for example
when the goal is to "make holes" with one theme in another, is to st_union
the two themes, then re-attribute, then delete the unwanted polygons.  This
has worked for me in relatively small datasets but I've never truly stress
tested it.
2011/9/7 Nicolas Ribot <nicolas.ribot at gmail.com>
> > Hello Group,
> > About st_difference I've seen several topics but unfortunately with none
> of them I could solve my problem.
> > What I want to do is subtract one layer from the other. I could simplify
> this down to the following;
> > Tbl_a contains 1 record
> > "POLYGON(((168119.443682473 451093.811197312,197555.469699649
> 451093.811197312,197555.469699649 437539.54805452,168119.443682473
> 437539.54805452,168119.443682473 437539.54805452,168119.443682473
> 451093.811197312)))"
> > Tbl_b contains 2 records of which both intersects with the object in
> tbl_a
> > "POLYGON(((171424.484910418 453680.34544058,171424.484910418
> 435697.56759188,174568.140889894 435697.56759188,174568.140889894
> 453680.34544058,174568.140889894 453680.34544058,171424.484910418
> 453680.34544058)))"
> > "POLYGON(((184904.90800885 453627.063135843,184904.90800885
> 435644.285287143,188048.563988327 435644.285287143,188048.563988327
> 453627.063135843,188048.563988327 453627.063135843,184904.90800885
> 453627.063135843)))"
> > The result I'm looking for is the object of tbl_a abstracted with both
> objects from tbl_b, since they are both intersecting. In this example the
> result should be 3 squares since it is cut twice by tbl_b.
> > Does anyone know a solution for this?
> > Many thanks in advance,
> > Ge
> Hi Ge,
> You may want to union objects in table B to create a single polygon,
> then perfom the difference:
> select st_difference(a.geom, b.geom)
> from
> (select 'POLYGON((168119.443682473 451093.811197312,197555.469699649
> 451093.811197312))'::geometry as geom) as a,
> select st_union(geom) as geom
> from (
>        select 'POLYGON((171424.484910418 453680.34544058,171424.484910418
> 453680.34544058))'::geometry as geom
>        UNION
>        select 'POLYGON((184904.90800885 453627.063135843,184904.90800885
> 453627.063135843))'::geometry as geom
> ) as foo
> ) as b;
> (see attached pictures)
> Nicolas
> postgis-users mailing list
Chris Hermansen
*Vice President*
TECO Natural Resource Group Limited
301 · 958 West 8th Avenue
Vancouver BC CANADA · V5Z 1E5
Tel +1.604.714.2878 · Cel +1.778.840.4625
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110907/945e41a4/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110907/945e41a4/attachment.jpg>
