[postgis-users] OT How do I return a list of id's from a stored procedure from a dynamicly generated insert?
rox
rox at tara-lu.com
Thu Sep 8 06:25:03 PDT 2011
On Wed, 07 Sep 2011 17:10:59 -0400, rox wrote:
> Postgres 8.3 [altho if 8.4 is required to solve this, that is
> possible]
sorry - OT should have been on the postgres list. In case someone
searches
and finds the question, resolution shown below:
CREATE OR REPLACE FUNCTION test_insert(p_table_name varchar) RETURNS
TABLE (i int) AS $f$
DECLARE
qs1 varchar(3000);
BEGIN
qs1 := 'INSERT INTO ' || p_table_name ;
qs1 := qs1 || ' (table_id,name) ';
qs1 := qs1 || '(';
qs1 := qs1 || ' SELECT nextval(''test_inserts_table_id_seq''),';
qs1 := qs1 || ' county_name';
qs1 := qs1 || ' FROM counties';
qs1 := qs1 || ')';
qs1 := qs1 || 'RETURNING table_id';
qs1 := qs1 || ';';
RAISE INFO 'query:%',qs1;
RETURN QUERY EXECUTE qs1 ;
EXCEPTION
WHEN OTHERS THEN
RAISE INFO 'error:% %',SQLSTATE,sqlerrm;
RETURN QUERY select -1;
END;
$f$ LANGUAGE plpgsql VOLATILE;
> executing via
> select test_insert('test_inserts') as intarray;
change to select test_insert('test_inserts')
