[postgis-users] Installer bugs ?
poultee
simple_hot_ice at yahoo.com
Mon Sep 12 19:51:55 PDT 2011
Installing using method 2) works. I did not notice that the PGBIN and
PGLIB vars were not indicating to were i installed postgres. So problem
is pretty much solved... Method 1) of installing still doesn't work
tho. ( Ability to install postgis directly from stack builder would
be appreciated ^-^)
On 9/13/2011 5:14 AM, poultee wrote:
> I'm not sure i know what sql i should use to execute manually ( the
> -d -f -c params are a little confusing to somebody who does not use
> psql, like me for example ^-^). So someone please post the script that
> does what the bat was supposed to do :D
> On 9/13/2011 5:08 AM, poultee wrote:
>> Hello,
>> 1) Just upgraded to postgres 9.0 and wanted to install postgis using
>> stack builder...the installer gets downloaded but when i execute i
>> get a message saying i already have the postgis template DB...Which
>> is not true..at least not on 9.0; I choose to create a new one but
>> the i get an error message saying removal of template_postgis failed.
>> BECAUSE "psql: FATAL: database "template_postgis" does not exist"
>> :)).. So i cant install this way at all (at least so it seems)
>> 2)I tried using the bat file from and it copies the db file and
>> when it gets to the create DB part i get a message saying psql is
>> not recognized as an internal or external commannd, operable program
>> or batch file
> postgis-users mailing list
