[postgis-users] Installer bugs ?
poultee simple_hot_ice at yahoo.com
Mon Sep 12 19:14:38 PDT 2011
I'm not sure i know what sql i should use to execute manually  ( the -d
-f -c params are a little confusing to somebody who does not use psql,
like me for example ^-^). So someone please post the script that does
what the bat was supposed to do :D
On 9/13/2011 5:08 AM, poultee wrote:
> Hello,
> 1) Just upgraded to postgres 9.0 and wanted to  install postgis using
> stack builder...the installer gets downloaded but when i execute i get
> a message saying i already have the postgis template DB...Which is not
> true..at least not on 9.0; I choose to create a new one but the i get
> an error message saying removal of template_postgis failed. BECAUSE
> "psql: FATAL:  database "template_postgis" does not exist" :)).. So i
> cant install this  way at all (at least so it seems)
> 2)I tried  using the bat file from  and it copies the db file and when
> it gets to the create  DB part  i get a message saying psql is not
> recognized as an internal or external commannd, operable program or
> batch file
