[postgis-users] ST_Extent of table
Sandro Santilli
strk at keybit.net
Mon Sep 19 10:56:54 PDT 2011
On Mon, Sep 19, 2011 at 01:22:29PM -0400, Javier de la Torre wrote:
> Ups.
> The function works on 1.5.3 but not in 2.0SVN
> In 2.0 I get:
> ERROR: geometry_estimated_extent: couldn't locate table within current schema
Specify the schema explicitly ?
SELECT ST_Estimated_Extent('"MySchema"', '"MyTable"');
Show your call if that's not the problem.
Also make sure you have r7868 or later, to avoid getting weird results.
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
