[postgis-users] Simple ST_Value(rast, point)
Paragon Corporation
lr at pcorp.us
Mon Sep 19 14:46:55 PDT 2011
Andreas,
Off hand I think you are missing some intersects checks and are therefore
doing much more work than you need to
Don't you want to check only raasters where
ST_Intersects(p90.rast, p.centroid) AND ST_Intersects(p95.rast, p.centroid)
etc etc.
Regina
http://www.postgis.us
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Andreas Forø Tollefsen
> Sent: Monday, September 19, 2011 11:51 AM
> To: PostGIS Users Discussion
> Subject: [postgis-users] Simple ST_Value(rast, point)
> Hi all,
> I just wanted to get some feedback on my query. Basically, it
> is simply to create a new table with the raster values of my
> 6 population rasters overlapping my regularly separated point dataset.
> Is this an optimal way of doing this? Reason I ask is that it
> does take a lot of time.
> DROP TABLE IF EXISTS popgrid;
> SELECT gid,
> ST_Value(p90.rast, SetSRID(p.centroid,4326)) as pop90,
> ST_Value(p95.rast, SetSRID(p.centroid,4326)) as pop95,
> ST_Value(p00.rast, SetSRID(p.centroid,4326)) as pop00,
> ST_Value(p05.rast, SetSRID(p.centroid,4326)) as pop05,
> ST_Value(p10.rast, SetSRID(p.centroid,4326)) as pop10,
> ST_Value(p15.rast, SetSRID(p.centroid,4326)) as pop15 INTO
> popgrid FROM pop90 p90, pop95 p95, pop00 p00, pop05 p05,
> pop10 p10, pop15 p15, priogrid p ;
> Best,
> Andreas
> postgis-users mailing list
