[postgis-users] Simple ST_Value(rast, point)
Andreas Forø Tollefsen andreasft at gmail.com
Mon Sep 19 17:02:26 PDT 2011
Somehow that result in an error.
Query:
DROP TABLE IF EXISTS popgrid;
SELECT gid,
ST_Value(p90.rast, SetSRID(p.centroid,4326)) as pop90,
ST_Value(p95.rast, SetSRID(p.centroid,4326)) as pop95,
ST_Value(p00.rast, SetSRID(p.centroid,4326)) as pop00,
ST_Value(p05.rast, SetSRID(p.centroid,4326)) as pop05,
ST_Value(p10.rast, SetSRID(p.centroid,4326)) as pop10,
ST_Value(p15.rast, SetSRID(p.centroid,4326)) as pop15
INTO popgrid
FROM pop90 p90, pop95 p95, pop00 p00, pop05 p05, pop10 p10, pop15 p15,
priogrid p
WHERE ST_Intersects(p90.rast, p.centroid)
AND ST_Intersects(p95.rast, p.centroid)
AND ST_Intersects(p00.rast, p.centroid)
AND ST_Intersects(p05.rast, p.centroid)
AND ST_Intersects(p10.rast, p.centroid)
AND ST_Intersects(p15.rast, p.centroid)
Result:
ERROR:  lower bound of FOR loop cannot be null
CONTEXT:  PL/pgSQL function "_st_intersects" line 96 at FOR with
integer loop variable
********** Error **********
SQL state: 22004
Context: PL/pgSQL function "_st_intersects" line 96 at FOR with
Something fishy going on here?
Rev 7862.
2011/9/19 Paragon Corporation <lr at pcorp.us>:
> Andreas,
> Off hand I think you are missing some intersects checks and are therefore
> doing much more work than you need to
> Don't you want to check only raasters where
> ST_Intersects(p90.rast, p.centroid) AND ST_Intersects(p95.rast, p.centroid)
> etc etc.
> Regina
> http://www.postgis.us
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] On
>> Behalf Of Andreas Forø Tollefsen
>> Sent: Monday, September 19, 2011 11:51 AM
>> To: PostGIS Users Discussion
>> Subject: [postgis-users] Simple ST_Value(rast, point)
>> Hi all,
>> I just wanted to get some feedback on my query. Basically, it
>> is simply to create a new table with the raster values of my
>> 6 population rasters overlapping my regularly separated point dataset.
>> Is this an optimal way of doing this? Reason I ask is that it
>> does take a lot of time.
>> SELECT gid,
>> ST_Value(p15.rast, SetSRID(p.centroid,4326)) as pop15 INTO
>> popgrid FROM pop90 p90, pop95 p95, pop00 p00, pop05 p05,
>> pop10 p10, pop15 p15, priogrid p ;
>> Best,
>> Andreas
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
