[postgis-users] copying tables from one schema to another
Mr. Puneet Kishor
punk.kish at gmail.com
Thu Sep 22 05:16:54 PDT 2011
On Sep 22, 2011, at 6:29 AM, Robert Buckley wrote:
> Hi,
> As a follow-up to my earlier post (Re: [postgis-users] schemas and postgis data) I have another question.
> I had originally put all my data into the public schema. I want to move my geodata to the schema "data", so I just used to following command in the pgadmin3 sql editor
> create table data.new_table as (select * from public.old_table);
Don't recreate the tables. Just alter the schema. Check the Pg docs for changing the schema.
> although this works, the schema is not copied..ie the primary key and other contraints are missing.
> So i have done this
> # first create new table and copy schema
> create table data.table_2(like table_1 including defaults including constraints including indexes);
> #then copy data into table_2
> insert into data.table2(select * from public.table_1);
> Is there a better/quicker/safer way of doing this? possibly with pgadmin3?_______________________________________________
> postgis-users mailing list
