[postgis-users] how to select points outside polygons?
Stephen Woodbridge woodbri at swoodbridge.com
Thu Sep 29 16:20:32 PDT 2011
On 9/29/2011 5:55 PM, Vishal Mehta wrote:
> *Hi Steve, *
> I tried that
> select powerplants.gid, plantname
>       from powerplants, pca_huc
>     where state ='CA'
>                 AND NOT st_contains(pca_huc.geom,powerplants.geom)
>     order by powerplants.gid;
> but got some 44,000 rows in the result. There are 1477 powerplants
> (points) and 299 pca_huc polygons. The powerplants don’t all fall inside
> the polygons, and I want to get the list of those that fall outside.
> In a desktop gis I can quickly select and see that 102 powerplants fall
> outside: so I should not be getting 44,0000 rows in the result…
Ahhh! that is a different problem! you want the points the do not fall
in ANY polygon, so you need to first union or collect all you polygons
into a single object and then ask which point are out that object.
So maybe this will work:
   from powerplants,
        (select st_collect(geom) as geom from pca_huc) as pca
  where state ='CA'
        AND NOT st_contains(pca.geom,powerplants.geom)
If that does not work then try:
   from powerplants,
        (select st_union(geom) as geom from pca_huc) as pca
  where state ='CA'
-Steve
> V
> Did you try:
>     where state ='CA'
> This should give you all power plants in CA and not in your contains
> clause. What is the coverage of pca_huc table? If this covers all of CA
> then there is not possible result. The would be like say where a=1 and
> not a=1.
> -Steve W
> On 9/29/2011 1:21 PM, Vishal Mehta wrote:
>>/  I have a point layer and a polygon layer. How do I select points that/
>>/  are NOT contained within polygons?/
>>/  For example, this query correctly selects points contained by polygons/
>>/  select powerplants.gid, plantname/
>>/  from powerplants, pca_huc/
>>/  where state ='CA'   /
>>/  AND/
>>/  st_contains(pca_huc.geom,powerplants.geom)/
>>/  order by powerplants.gid;/
>>/  I tried to get the inverse selection using st_disjoint instead of/
>>/  st_contains , but that did not work. I also tried using NOT and EXCEPT/
>>/  without success (although I may not have constructed the latter queries/
>>/  correctly..)/
>>/  Thanks!/
>>/  Vishal/
> /Vishal K. Mehta <http://sei-us.org/about/staff_person/19>, Ph.D. /
> /Staff Scientist, /
> /Stockholm Environment Institute-US /
> /400 F St, Davis, CA 95616 /
> /http://sei-us.org/ /
> postgis-users mailing list
