[postgis-users] how to select points outside polygons?
Vishal Mehta
vishal.mehta at sei-us.org
Thu Sep 29 14:55:12 PDT 2011
Hi Steve,
I tried that
select powerplants.gid, plantname
from powerplants, pca_huc
where state = 'CA'
AND NOT st_contains(pca_huc.geom,powerplants.geom)
order by powerplants.gid;
but got some 44,000 rows in the result. There are 1477 powerplants (points) and 299 pca_huc polygons. The powerplants don't all fall inside the polygons, and I want to get the list of those that fall outside.
In a desktop gis I can quickly select and see that 102 powerplants fall outside: so I should not be getting 44,0000 rows in the result...
V
Did you try:
where state = 'CA'
This should give you all power plants in CA and not in your contains
clause. What is the coverage of pca_huc table? If this covers all of CA
then there is not possible result. The would be like say where a=1 and
not a=1.
-Steve W
On 9/29/2011 1:21 PM, Vishal Mehta wrote:
> I have a point layer and a polygon layer. How do I select points that
> are NOT contained within polygons?
> For example, this query correctly selects points contained by polygons
> where state = 'CA'
> AND
> I tried to get the inverse selection using st_disjoint instead of
> st_contains , but that did not work. I also tried using NOT and EXCEPT
> without success (although I may not have constructed the latter queries
> correctly..)
> Thanks!
> Vishal
Vishal K. Mehta<http://sei-us.org/about/staff_person/19>, Ph.D.
Staff Scientist,
Stockholm Environment Institute-US
400 F St, Davis, CA 95616
http://sei-us.org/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110929/fe9a2001/attachment.html>
