[postgis-users] how to select points outside polygons?
Stephen Woodbridge woodbri at swoodbridge.com
Thu Sep 29 11:22:45 PDT 2011
Did you try:
select powerplants.gid, plantname
   from powerplants, pca_huc
  where state = 'CA'
        AND NOT st_contains(pca_huc.geom,powerplants.geom)
  order by powerplants.gid;
This should give you all power plants in CA and not in your contains
clause. What is the coverage of pca_huc table? If this covers all of CA
then there is not possible result. The would be like say where a=1 and
not a=1.
-Steve W
On 9/29/2011 1:21 PM, Vishal Mehta wrote:
> I have a point layer and a polygon layer. How do I select points that
> are NOT contained within polygons?
> For example, this query correctly selects points contained by polygons
> where state = 'CA'
> AND
> I tried to get the inverse selection using st_disjoint instead of
> st_contains , but that did not work. I also tried using NOT and EXCEPT
> without success (although I may not have constructed the latter queries
> correctly..)
> Thanks!
> Vishal
> postgis-users mailing list
