[postgis-users] Convert from character to timestamptz
Mathieu Basille
basille at ase-research.org
Fri Sep 30 09:10:00 PDT 2011
Dear PostGIS users,
I've been trying for hours with no result... My problem is that I import
a simple shapefile (points) to PostGIS using shp2pgsql. In the attribute
table, there is a 'date' column formatted as '2005-03-20 00:00:00
EST5EDT'. This column is then imported as a 'character' column into
PostGIS. Now, I'd like to convert this column to a real 'timestamp with
time zone'. I tried many things like:
ALTER TABLE test
ALTER COLUMN date SET DATA TYPE timestamptz;
or
SELECT TIMESTAMP WITH TIME ZONE 'date' FROM test;
and all return an error, while e.g.:
SELECT TIMESTAMP WITH TIME ZONE '2005-03-20 00:00:00 EST5EDT';
perfectly works... I also tried:
SELECT to_timestamp(date, 'YYYY-MM-DD HH24:MI:SS TZ') FROM test;
which also returns an error stating that 'TZ'/'tz' are unsupported in
'to_date' (!). It works without the 'TZ', but I really need the timezone...
I have to admit I'm now totally in the dark and feel I really miss
something obvious. This might be a strict PostgreSQL question... In this
case, I apologize, as I couldn't find my answers either after reading
several times the doc on date/time for PostgreSQL...
Thanks for any hint!
All the best,
Mathieu.
~$ whoami
Mathieu Basille, Post-Doc
~$ locate
Laboratoire d'Écologie Comportementale et de Conservation de la Faune
+ Centre d'Étude de la Forêt
Département de Biologie
Université Laval, Québec
~$ info
http://ase-research.org/basille
~$ fortune
``If you can't win by reason, go for volume.''
Calvin, by Bill Watterson.
