[postgis-users] Convert from character to timestamptz
Mathieu Basille basille at ase-research.org
Fri Sep 30 09:33:30 PDT 2011
Dear Sandro,
You're right, I'm being too vague (in my defence, error messages are in
French for me!). Let's try to be more specific. Attached is a simple
shapefile (4 points). It imports correctly with:
shp2pgsql -s 26919 -I test.shp test | psql -h localhost -d geodb -U
caribou -q
Now, if I try:
SELECT TIMESTAMP WITH TIME ZONE 'date' FROM test;
I receive the following error:
********** Error **********
ERREUR: syntaxe en entrée invalide pour le type timestamp with time zone
: « date » [~ invalid syntax for the type timestamp with time zone]
SQL state: 22007
Character: 33
With the command:
ALTER TABLE test
     ALTER COLUMN date SET DATA TYPE timestamptz;
the error is:
ERREUR: la colonne « date » ne peut pas être convertie vers le type
timestamp with time zone [~ column 'date' can't be converted to type
SQL state: 42804
And if I try what you suggested:
ALTER TABLE test
     ALTER COLUMN date TYPE timestamptz
     WITH date::timestamptz;
the error is:
ERREUR: erreur de syntaxe sur ou près de « WITH date » [~ syntax error
on or near 'WITH date']
SQL state: 42601
Character: 61
Thanks again for your help!
Mathieu.
Le 30/09/2011 12:15, Sandro Santilli a écrit :
> On Fri, Sep 30, 2011 at 12:10:00PM -0400, Mathieu Basille wrote:
>> Dear PostGIS users,
>> I've been trying for hours with no result... My problem is that I
>> import a simple shapefile (points) to PostGIS using shp2pgsql. In
>> the attribute table, there is a 'date' column formatted as
>> '2005-03-20 00:00:00 EST5EDT'. This column is then imported as a
>> 'character' column into PostGIS. Now, I'd like to convert this
>> column to a real 'timestamp with time zone'. I tried many things
>> like:
>> ALTER TABLE test
>> or
>> and all return an error
> You should report the error, when you get one.
> I can just "guess" that the second is invalid syntax as you're
> using the literal string 'date' rather than the identifier "date".
> And I can "guess" that the first is a syntax error (but I'm not sure).
> I'd write the first as:
>   ALTER TABLE test
> Or something like that (but would really first lookup the reference).
> --strk;
>    ()   Free GIS&  Flash consultant/developer
>    /\   http://strk.keybit.net/services.html
> postgis-users mailing list
~$ whoami
Mathieu Basille, Post-Doc
~$ locate
Laboratoire d'Écologie Comportementale et de Conservation de la Faune
+ Centre d'Étude de la Forêt
Département de Biologie
Université Laval, Québec
~$ info
http://ase-research.org/basille
~$ fortune
``If you can't win by reason, go for volume.''
Calvin, by Bill Watterson.
Type: application/x-dbf
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110930/bc69c848/attachment.bin>
Type: application/x-esri-shape
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110930/bc69c848/attachment-0001.bin>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110930/bc69c848/attachment-0002.bin>
