[postgis-users] Shp2pgsql-gui, Save to schema other than public?
Francois Hugues hugues.francois at irstea.fr
Tue Apr 17 01:32:48 PDT 2012
Did you try to edit manually the name of the shema ? That should be ok and you can do the same to set the table name, geometry column and srid.
Hug
De : postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] De la part de Ryan Dalton
Envoyé : mardi 17 avril 2012 06:25
À : postgis-users at postgis.refractions.net
Objet : [postgis-users] Shp2pgsql-gui, Save to schema other than public?
I just got PostGIS 2.0 installed and was using the Shp2pgsql-gui to load some shapefiles into the database.  I have created a 'data' schema where I was planning to store all of my imported data, but when I use the shapefile import GUI, it does not appear as though there is an option to specify which schema to load the data into, and it just goes into 'public'.
Is it possible to load to an alternate schema, and am I just missing something obvious?  Maybe a future feature enhancement if not?
Thanks,
Ryan
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120417/3dffc5d5/attachment.html>
