[postgis-users] Adding geometry to an existing table
Charlie Sharpsteen
charles.sharpsteen at gmail.com
Sat Apr 28 16:08:43 PDT 2012
On Saturday, April 28, 2012 12:03:09 PM UTC-7, pcr... at pcreso.com wrote:
> Hi Shaun,
> You add a geometry column to the table, then run an update sql to populate
> it.
> eg, assuming your table is called mytable, located in the public schema, &
> you want to create a two dimensional point with lat/long coordinates
> (EPSG:4326) called "geom":
And _assuming your lat/lon coordinates are referenced to WGS 84_ or, for
small to medium scales, NAD 83---then EPSG:4326 is the right coordinate
system. Not all lat/lon coordinates are equal.
For example the error between mis-identifying lat/lon in NAD 27 as lat/lon
in WGS 84 is about half a city block.
-Charlie
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120428/124bb2e1/attachment.html>
