[postgis-users] area and distance
Muhammad Imran imranserver at yahoo.com
Thu Aug 2 14:46:06 PDT 2012
Hi Chandler,
Did you check projection system of the both Geometries? Just to make sure, use ST_TRANSFORM as inner function.
regards
Muhammad Imran
--- On Fri, 8/3/12, CHANDLER DOUGLAS COLEMAN <CHANDLER.D.COLEMAN at stu.mmu.ac.uk> wrote:
From: CHANDLER DOUGLAS COLEMAN <CHANDLER.D.COLEMAN at stu.mmu.ac.uk>
Subject: [postgis-users] area and distance
To: "postgis-users at postgis.refractions.net" <postgis-users at postgis.refractions.net>
Date: Friday, August 3, 2012, 3:01 AM
#yiv946520484 P {margin-top:0;margin-bottom:0;}
Hello,
I am a newbie to PostGIS.  I am hoping some one can explain to me why the following simple query doesn't return any info:
SELECT f.fact_name
FROM factory AS f, inner_area AS i
WHERE i.name = 'Dewsbury'
AND ST_WITHIN (f.geom,i.geom);
I have geom in as a column and I have 'Dewsbury' as a polygon record in inner_area and there are 5 records in factory that fall within this polygon.  But the resulting table shows that none were selected.
My assumption here is that the SQL statement is correct, but that something is wrong with the tables:  could it be how I imported the two tables from shapefiles.
Thanks,
Chandler
-----Inline Attachment Follows-----
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120802/fa7ac509/attachment.html>
