[postgis-users] Compilation problem for Postgis-1.5.4 on Debian Squeeze
Eric
ericfrancois at hotmail.com
Tue Jul 3 14:27:46 PDT 2012
Hello,
Ive some problems to make Postgis-1.5.4 compilation On Debian Squeeze.
After the ./configure , make command end like that:
gcc -g -O2 -g -Wall -O2 -fPIC -Wall -Wmissing-prototypes -Wpointer-arith
-Wdeclaration-after-statement -Wendif-labels -fno-strict-aliasing -fwrapv -g
-fpic -I/usr/include -I/usr/include/libxml2 -I../liblwgeom -I. -I.
-I/usr/include/postgresql/9.0/server -I/usr/include/postgresql/internal
-D_GNU_SOURCE -I/usr/include/libxml2 -I/usr/include/tcl8.5 -c -o
lwgeom_cache.o lwgeom_cache.c
In file included from lwgeom_cache.h:21,
from lwgeom_cache.c:16:
lwgeom_geos_prepared.h:60: erreur: expected :, ,, ;, } or
__attribute__ before * token
make[1]: *** [lwgeom_cache.o] Erreur 1
make[1]: quittant le répertoire « /source/postgis-1.5.4/postgis »
make: *** [postgis] Erreur 2
gcc (Debian 4.4.5-8) 4.4.5 on Debian Squeeze
The ./configure result:
PostGIS is now configured for i686-pc-linux-gnu
-------------- Compiler Info -------------
C compiler: gcc -g -O2
C++ compiler: g++ -g -O2
-------------- Dependencies --------------
GEOS config: /usr/bin/geos-config
GEOS version: 3.2.0
PostgreSQL config: /usr/bin/pg_config
PostgreSQL version: PostgreSQL 9.0.7
PROJ4 version: 47
Libxml2 config: /usr/bin/xml2-config
Libxml2 version: 2.7.8
PostGIS debug level: 0
-------- Documentation Generation --------
xsltproc: /usr/bin/xsltproc
xsl style sheets:
dblatex: /usr/bin/dblatex
convert: /usr/bin/convert
Thanks for any idea
Eric
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120703/c2e6c54a/attachment.html>
