[postgis-users] Problem with using query layer in ArcGIS
Simon Greener
simon at spatialdbadvisor.com
Tue Jul 3 18:04:23 PDT 2012
Can you interact with the postgresql/Postgis data natively (ie via pgAminIII) without error? Can't think of any case where this might not be the case. This smells very much like an ArcGIS/ArcSDE configuration problem. In the old days, when one used the ArcSDE administration command line tools, one would use sdelayer to create a layer over an existing table. That sdelayer command included arguments to tell ArcSDE what column contained the unique identifier and whether it was SDE maintained or user maintained. ArcSDE, back then, didn't require the column to be a primary key, only unique.
sdelayer -o add -l <table,column> -e <entity_mask>
[-t <storage_type>] [Spatial_Index][{-R <SRID> | [Spatial_Ref_Opts]}]
[-M <minimum_id>] [{-f <init_features,avg_points> | -k <config_keyword>}]
[-E <{empty | xmin,ymin,xmax,ymax}>] [-L {ON | OFF}]
[-C <row_id_column>[,{SDE|USER}[,<min_ID>]]] [-P {HIGH | BASIC}]
[-S <layer_description_str>] [-i {<service> | <port#> | <direct connection>}]
[-s <server_name>] [-D <database_name>] -u <DB_user_name>
-p <DB_user_password> [-q]
For -C .....
Specifies the name of the row ID column of the layer's business table and the optional minimum row ID value
For the register operation, it also specifies whether the row ID is to be registered as user or ArcSDE maintained. If ArcSDE maintained, you can specify the starting value (min_ID) for the row ID. If no minimum ID is specified, it defaults to 1. If you intend to register the feature class with the geodatabase, you should register the row ID column as ArcSDE maintained.
For the feature_info operation, it specifies the name of the row ID column that will be output to a table in the database.
Double check that this is your table/column configuration aligns with what I have said.
regards
Simon
On Wed, 04 Jul 2012 06:00:23 +1000, Melpati, Muni <Muni.Melpati at dot.state.fl.us> wrote:
> The selected unique identifier column is GID (created by postgis). So, it has to be unique >identifier.
> Based on the fact that I could see selected feature attributes or I could see attributes using >identifier tool,
> I have to assume that query tool retrieves this information upon user action (in this case >select a feature).
> That is why I am wondering if I need to modify something like it was done with SDE Server >config file to improve the performance of the query application. Thanks.
> Message: 18
> Date: Tue, 03 Jul 2012 17:50:55 +0200
> From: William Humphrey Temperley <william.temperley at jrc.ec.europa.eu>
> Subject: Re: [postgis-users] Problem with using query layer in ArcGIS
> 10
> To: "'PostGIS Users Discussion'"
> <postgis-users at postgis.refractions.net>
> Message-ID: <013c01cd5933$a1af3230$e50d9690$@jrc.ec.europa.eu>
> Content-Type: text/plain; charset="us-ascii"
> I haven't seen this behaviour -- being able to see the attributes with
> identify but not being able to use the attribute table properly.
> Are you 100% certain the unique identifier column you have chosen is unique,
> i.e. is it a primary key, or does it have a unique constraint on it?
> Duplicate keys might cause this behaviour, but I'm not sure.
> Will
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Melpati,
> Muni
> Sent: 03 July 2012 17:28
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Problem with using query layer in ArcGIS 10
> Hi William,
> Thank you for response. It is great that you showed interest in helping me
> on this. After playing with the query tool, it was very evident that I need
> to pick one single unique identifier field. The problem I am facing happens
> despite the fact that I selected one single field as unique identifier. I
> have two layers (one with 13,000 records and another with 55,600 records).
> Smaller file works like any other shape file. The larger file would through
> up loading data problem.
> Note: If I, either select a bunch features or use identify tool, I could
> see all the attributes. In other cases, though I could not see attributes, I
> could see all the features on the map.
> I could also use attribute query tool on the same data and select records
> and view them. However, I simply having trouble with opening the table and
> viewing all the records.
> Also I am unable to export to shapefile from ArcMap when this problem
> occurs.
> Thanks.
Holder of "2011 Oracle Spatial Excellence Award for Education and Research."
SpatialDB Advice and Design, Solutions Architecture and Programming,
Oracle Database 10g Administrator Certified Associate; Oracle Database 10g SQL Certified Professional
Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE, Manifold GIS, FME, Radius Topology and Studio Specialist.
39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia.
Website: www.spatialdbadvisor.com
Email: simon at spatialdbadvisor.com
Voice: +61 362 396397
Mobile: +61 418 396391
Skype: sggreener
Longitude: 147.20515 (147° 12' 18" E)
Latitude: -43.01530 (43° 00' 55" S)
GeoHash: r22em9r98wg
NAC:W80CK 7SWP3
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120704/dce58061/attachment.html>
