[postgis-users] Installing on Debian
Stefano Iacovella stefano.iacovella at gmail.com
Thu Jun 14 11:30:36 PDT 2012
Hi Alex
It sounds like you are missing the headers and include files for compilation.
Check if it is installed on your box:
stefano at vmora11gsrv:~$ dpkg -l | grep libxml2
ii  libxml-libxml-perl                  1.70.ds-1
   Perl interface to the libxml2 library
ii  libxml2                             2.7.6.dfsg-1ubuntu1.5
   GNOME XML library
ii  libxml2-dev                         2.7.6.dfsg-1ubuntu1.5
   Development files for the GNOME XML library
if it is not than you can add it with aptitude:
sudo apt-get install libxml2-dev
Hope it helps
Stefano
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
2012/6/14 aborrell <borrellalex at gmail.com>:
> Hi Paolo, thanks for your post about postgis 2.0. I've been trying to install
> it on an OSGeo 5.5 Ubuntu live dvd installed on a hard disk. I managed to
> get Postgresql 9.1 working, but when I try to configure Postgis 2.0 I get
> the following error:
> ./configure --with-pgconfig=/usr/lib/postgresql/9.1/bin/pg_config
> --with-geosconfig=/usr/bin/geos-config --with-jsondir=/usr --with-topology
> --with-raster
> checking libpq-fe.h presence... yes
> checking for libpq-fe.h... yes
> checking for PQserverVersion in -lpq... yes
> checking for xml2-config... /usr/bin/xml2-config
> checking libxml/tree.h usability... yes
> checking libxml/tree.h presence... yes
> checking for libxml/tree.h... yes
> checking libxml/parser.h usability... yes
> checking libxml/parser.h presence... yes
> checking for libxml/parser.h... yes
> checking libxml/xpath.h usability... yes
> checking libxml/xpath.h presence... yes
> checking for libxml/xpath.h... yes
> checking libxml/xpathInternals.h usability... yes
> checking libxml/xpathInternals.h presence... yes
> checking for libxml/xpathInternals.h... yes
> checking for xmlInitParser in -lxml2... no
> configure: error: could not find libxml2
> I can't make it work. xml2-config is in /usr/bin, libxml2 in
> /usr/include/libxml2/libxml and libxml2.so, libxml2.a in
> /usr/lib/i386-linux-gnu
> I would appreciate your help. Thanks
> Alex Borell
> Mexico
> View this message in context: http://postgis.17.n6.nabble.com/Installing-on-Debian-tp4996113p4998272.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
