[postgis-users] Installing on Debian
Alex Borrell
borrellalex at gmail.com
Thu Jun 14 11:59:38 PDT 2012
Thanks for help Stefano,
I run the command, it seems to be installed, here are the results:
aborrell at geo4:/usr/lib$ dpkg -l | grep libxml2
ii libxml-libxml-perl
1.89+dfsg-1 Perl interface to the libxml2
library
ii libxml2
2.8.0+dfsg1-3 GNOME XML library
ii libxml2-dbg
2.8.0+dfsg1-3 Debugging symbols for the GNOME
XML library
ii libxml2-dev
2.8.0+dfsg1-3 Development files for the GNOME
XML library
ii libxml2-utils
2.8.0+dfsg1-3 XML utilities
ii libxml2-utils-dbg
2.8.0+dfsg1-3 XML utilities (debug extension)
ii python-libxml2
2.8.0+dfsg1-3 Python bindings for the GNOME
XML library
ii python-lxml
2.3.2-1 pythonic binding for the libxml2
and libxslt libraries
The machine is running Ubuntu 12.04 with some libraries from debian testing.
Thanks again for your kind help,
Alex
On Thu, Jun 14, 2012 at 1:30 PM, Stefano Iacovella <
stefano.iacovella at gmail.com> wrote:
> Hi Alex
> It sounds like you are missing the headers and include files for
> compilation.
> Check if it is installed on your box:
> stefano at vmora11gsrv:~$ dpkg -l | grep libxml2
> ii libxml-libxml-perl 1.70.ds-1
> Perl interface to the libxml2 library
> ii libxml2 2.7.6.dfsg-1ubuntu1.5
> GNOME XML library
> ii libxml2-dev 2.7.6.dfsg-1ubuntu1.5
> Development files for the GNOME XML library
> if it is not than you can add it with aptitude:
> sudo apt-get install libxml2-dev
> Hope it helps
> Stefano
> 41.95581N 12.52854E
> http://www.linkedin.com/in/stefanoiacovella
> http://twitter.com/#!/Iacovellas
> 2012/6/14 aborrell <borrellalex at gmail.com>:
> > Hi Paolo, thanks for your post about postgis 2.0. I've been trying to
> install
> > it on an OSGeo 5.5 Ubuntu live dvd installed on a hard disk. I managed to
> > get Postgresql 9.1 working, but when I try to configure Postgis 2.0 I get
> > the following error:
> > ./configure --with-pgconfig=/usr/lib/postgresql/9.1/bin/pg_config
> > --with-geosconfig=/usr/bin/geos-config --with-jsondir=/usr
> --with-topology
> > --with-raster
> > checking libpq-fe.h presence... yes
> > checking for libpq-fe.h... yes
> > checking for PQserverVersion in -lpq... yes
> > checking for xml2-config... /usr/bin/xml2-config
> > checking libxml/tree.h usability... yes
> > checking libxml/tree.h presence... yes
> > checking for libxml/tree.h... yes
> > checking libxml/parser.h usability... yes
> > checking libxml/parser.h presence... yes
> > checking for libxml/parser.h... yes
> > checking libxml/xpath.h usability... yes
> > checking libxml/xpath.h presence... yes
> > checking for libxml/xpath.h... yes
> > checking libxml/xpathInternals.h usability... yes
> > checking libxml/xpathInternals.h presence... yes
> > checking for libxml/xpathInternals.h... yes
> > checking for xmlInitParser in -lxml2... no
> > configure: error: could not find libxml2
> > I can't make it work. xml2-config is in /usr/bin, libxml2 in
> > /usr/include/libxml2/libxml and libxml2.so, libxml2.a in
> > /usr/lib/i386-linux-gnu
> > I would appreciate your help. Thanks
> > Alex Borell
> > Mexico
> > View this message in context:
> http://postgis.17.n6.nabble.com/Installing-on-Debian-tp4996113p4998272.html
> > Sent from the PostGIS - User mailing list archive at Nabble.com.
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120614/4cf1cf44/attachment.html>
