[postgis-users] Installing on Debian
Alex Borrell
borrellalex at gmail.com
Fri Jun 15 07:56:57 PDT 2012
I manage to install postgresql 9.1/postgis 2.0 in a virtual machine with
debian sid. So
it solved the problem somehow. The libxml2 problem in Ubuntu 12.04 remains,
but I
will compare it with the debian system.
Thanks for your help!
On Thu, Jun 14, 2012 at 1:59 PM, Alex Borrell <borrellalex at gmail.com> wrote:
> Thanks for help Stefano,
> I run the command, it seems to be installed, here are the results:
> aborrell at geo4:/usr/lib$ dpkg -l | grep libxml2
> ii libxml-libxml-perl
> 1.89+dfsg-1 Perl interface to the libxml2
> library
> ii libxml2
> 2.8.0+dfsg1-3 GNOME XML library
> ii libxml2-dbg
> 2.8.0+dfsg1-3 Debugging symbols for the GNOME
> XML library
> ii libxml2-dev
> 2.8.0+dfsg1-3 Development files for the GNOME
> XML library
> ii libxml2-utils
> 2.8.0+dfsg1-3 XML utilities
> ii libxml2-utils-dbg
> 2.8.0+dfsg1-3 XML utilities (debug extension)
> ii python-libxml2
> 2.8.0+dfsg1-3 Python bindings for the GNOME
> XML library
> ii python-lxml
> 2.3.2-1 pythonic binding for the libxml2
> and libxslt libraries
> The machine is running Ubuntu 12.04 with some libraries from debian
> testing.
> Thanks again for your kind help,
> Alex
> On Thu, Jun 14, 2012 at 1:30 PM, Stefano Iacovella <
> stefano.iacovella at gmail.com> wrote:
>> Hi Alex
>> It sounds like you are missing the headers and include files for
>> compilation.
>> Check if it is installed on your box:
>> stefano at vmora11gsrv:~$ dpkg -l | grep libxml2
>> ii libxml-libxml-perl 1.70.ds-1
>> Perl interface to the libxml2 library
>> ii libxml2 2.7.6.dfsg-1ubuntu1.5
>> GNOME XML library
>> ii libxml2-dev 2.7.6.dfsg-1ubuntu1.5
>> Development files for the GNOME XML library
>> if it is not than you can add it with aptitude:
>> sudo apt-get install libxml2-dev
>> Hope it helps
>> Stefano
>> 41.95581N 12.52854E
>> http://www.linkedin.com/in/stefanoiacovella
>> http://twitter.com/#!/Iacovellas
>> 2012/6/14 aborrell <borrellalex at gmail.com>:
>> > Hi Paolo, thanks for your post about postgis 2.0. I've been trying to
>> install
>> > it on an OSGeo 5.5 Ubuntu live dvd installed on a hard disk. I managed
>> to
>> > get Postgresql 9.1 working, but when I try to configure Postgis 2.0 I
>> get
>> > the following error:
>> > ./configure --with-pgconfig=/usr/lib/postgresql/9.1/bin/pg_config
>> > --with-geosconfig=/usr/bin/geos-config --with-jsondir=/usr
>> --with-topology
>> > --with-raster
>> > checking libpq-fe.h presence... yes
>> > checking for libpq-fe.h... yes
>> > checking for PQserverVersion in -lpq... yes
>> > checking for xml2-config... /usr/bin/xml2-config
>> > checking libxml/tree.h usability... yes
>> > checking libxml/tree.h presence... yes
>> > checking for libxml/tree.h... yes
>> > checking libxml/parser.h usability... yes
>> > checking libxml/parser.h presence... yes
>> > checking for libxml/parser.h... yes
>> > checking libxml/xpath.h usability... yes
>> > checking libxml/xpath.h presence... yes
>> > checking for libxml/xpath.h... yes
>> > checking libxml/xpathInternals.h usability... yes
>> > checking libxml/xpathInternals.h presence... yes
>> > checking for libxml/xpathInternals.h... yes
>> > checking for xmlInitParser in -lxml2... no
>> > configure: error: could not find libxml2
>> > I can't make it work. xml2-config is in /usr/bin, libxml2 in
>> > /usr/include/libxml2/libxml and libxml2.so, libxml2.a in
>> > /usr/lib/i386-linux-gnu
>> > I would appreciate your help. Thanks
>> > Alex Borell
>> > Mexico
>> > View this message in context:
>> http://postgis.17.n6.nabble.com/Installing-on-Debian-tp4996113p4998272.html
>> > Sent from the PostGIS - User mailing list archive at Nabble.com.
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120615/ab274194/attachment.html>
