[postgis-users] Installing on Debian
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Fri Jun 15 10:26:03 PDT 2012
Pehaps Check if you have a bad symbolic link on libxml2.so
I had an issue with that
Alex Borrell <borrellalex at gmail.com>@postgis.refractions.net
Envoyé par : postgis-users-bounces at postgis.refractions.net
2012-06-15 10:56
Veuillez répondre à
PostGIS Users Discussion <postgis-users at postgis.refractions.net>
A
cc
Objet
Re: [postgis-users] Installing on Debian
I manage to install postgresql 9.1/postgis 2.0 in a virtual machine with
debian sid. So
it solved the problem somehow. The libxml2 problem in Ubuntu 12.04
remains, but I
will compare it with the debian system.
Thanks for your help!
On Thu, Jun 14, 2012 at 1:59 PM, Alex Borrell <borrellalex at gmail.com>
wrote:
Thanks for help Stefano,
I run the command, it seems to be installed, here are the results:
aborrell at geo4:/usr/lib$ dpkg -l | grep libxml2
ii  libxml-libxml-perl
1.89+dfsg-1                                Perl interface to the libxml2
library
ii  libxml2
2.8.0+dfsg1-3                              GNOME XML library
ii  libxml2-dbg
2.8.0+dfsg1-3                              Debugging symbols for the GNOME
XML library
ii  libxml2-dev
2.8.0+dfsg1-3                              Development files for the GNOME
XML library
ii  libxml2-utils
2.8.0+dfsg1-3                              XML utilities
ii  libxml2-utils-dbg
2.8.0+dfsg1-3                              XML utilities (debug extension)
ii  python-libxml2
2.8.0+dfsg1-3                              Python bindings for the GNOME
XML library
ii  python-lxml
2.3.2-1                                    pythonic binding for the
libxml2 and libxslt libraries
The machine is running Ubuntu 12.04 with some libraries from debian
testing.
Thanks again for your kind help,
Alex
On Thu, Jun 14, 2012 at 1:30 PM, Stefano Iacovella <
stefano.iacovella at gmail.com> wrote:
Hi Alex
It sounds like you are missing the headers and include files for
compilation.
Check if it is installed on your box:
stefano at vmora11gsrv:~$ dpkg -l | grep libxml2
ii  libxml-libxml-perl                  1.70.ds-1
  Perl interface to the libxml2 library
ii  libxml2                             2.7.6.dfsg-1ubuntu1.5
  GNOME XML library
ii  libxml2-dev                         2.7.6.dfsg-1ubuntu1.5
  Development files for the GNOME XML library
if it is not than you can add it with aptitude:
sudo apt-get install libxml2-dev
Hope it helps
Stefano
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
2012/6/14 aborrell <borrellalex at gmail.com>:
> Hi Paolo, thanks for your post about postgis 2.0. I've been trying to
install
> it on an OSGeo 5.5 Ubuntu live dvd installed on a hard disk. I managed
to
> get Postgresql 9.1 working, but when I try to configure Postgis 2.0 I
get
> the following error:
> ./configure --with-pgconfig=/usr/lib/postgresql/9.1/bin/pg_config
> --with-geosconfig=/usr/bin/geos-config --with-jsondir=/usr
--with-topology
> --with-raster
> checking libpq-fe.h presence... yes
> checking for libpq-fe.h... yes
> checking for PQserverVersion in -lpq... yes
> checking for xml2-config... /usr/bin/xml2-config
> checking libxml/tree.h usability... yes
> checking libxml/tree.h presence... yes
> checking for libxml/tree.h... yes
> checking libxml/parser.h usability... yes
> checking libxml/parser.h presence... yes
> checking for libxml/parser.h... yes
> checking libxml/xpath.h usability... yes
> checking libxml/xpath.h presence... yes
> checking for libxml/xpath.h... yes
> checking libxml/xpathInternals.h usability... yes
> checking libxml/xpathInternals.h presence... yes
> checking for libxml/xpathInternals.h... yes
> checking for xmlInitParser in -lxml2... no
> configure: error: could not find libxml2
> I can't make it work. xml2-config is in /usr/bin, libxml2 in
> /usr/include/libxml2/libxml and libxml2.so, libxml2.a in
> /usr/lib/i386-linux-gnu
> I would appreciate your help. Thanks
> Alex Borell
> Mexico
http://postgis.17.n6.nabble.com/Installing-on-Debian-tp4996113p4998272.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120615/722fdde9/attachment.html>
