[postgis-users] Installing on Debian
Alex Borrell borrellalex at gmail.com
Mon Jun 18 07:53:58 PDT 2012
Thanks Steve, I'll check that
On Fri, Jun 15, 2012 at 12:26 PM, <Steve.Toutant at inspq.qc.ca> wrote:
> Pehaps Check if you have a bad symbolic link on libxml2.so
> I had an issue with that
>  *Alex Borrell <borrellalex at gmail.com>@postgis.refractions.net*
> Envoyé par : postgis-users-bounces at postgis.refractions.net
> 2012-06-15 10:56
>  Veuillez répondre à
> PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>   A
> cc
>   Objet
> Re: [postgis-users] Installing on Debian
> Hi,
> I manage to install postgresql 9.1/postgis 2.0 in a virtual machine with
> debian sid. So
> it solved the problem somehow. The libxml2 problem in Ubuntu 12.04
> remains, but I
> will compare it with the debian system.
> Thanks for your help!
> On Thu, Jun 14, 2012 at 1:59 PM, Alex Borrell <*borrellalex at gmail.com*<borrellalex at gmail.com>>
> wrote:
> Thanks for help Stefano,
> I run the command, it seems to be installed, here are the results:
> aborrell at geo4:/usr/lib$ dpkg -l | grep libxml2
> ii  libxml-libxml-perl
> 1.89+dfsg-1                                Perl interface to the libxml2
> library
> ii  libxml2
> 2.8.0+dfsg1-3                              GNOME XML library
> ii  libxml2-dbg
> 2.8.0+dfsg1-3                              Debugging symbols for the GNOME
> XML library
> ii  libxml2-dev
> 2.8.0+dfsg1-3                              Development files for the GNOME
> XML library
> ii  libxml2-utils
> 2.8.0+dfsg1-3                              XML utilities
> ii  libxml2-utils-dbg
> 2.8.0+dfsg1-3                              XML utilities (debug extension)
> ii  python-libxml2
> 2.8.0+dfsg1-3                              Python bindings for the GNOME
> XML library
> ii  python-lxml
> 2.3.2-1                                    pythonic binding for the libxml2
> and libxslt libraries
> The machine is running Ubuntu 12.04 with some libraries from debian
> testing.
> Thanks again for your kind help,
> Alex
> On Thu, Jun 14, 2012 at 1:30 PM, Stefano Iacovella <*
> stefano.iacovella at gmail.com* <stefano.iacovella at gmail.com>> wrote:
> Hi Alex
> It sounds like you are missing the headers and include files for
> compilation.
> Check if it is installed on your box:
> stefano at vmora11gsrv:~$ dpkg -l | grep libxml2
> ii  libxml-libxml-perl                  1.70.ds-1
>   Perl interface to the libxml2 library
> ii  libxml2                             2.7.6.dfsg-1ubuntu1.5
>   GNOME XML library
> ii  libxml2-dev                         2.7.6.dfsg-1ubuntu1.5
>   Development files for the GNOME XML library
> if it is not than you can add it with aptitude:
> sudo apt-get install libxml2-dev
> Hope it helps
> Stefano
> 41.95581N 12.52854E
> **http://www.linkedin.com/in/stefanoiacovella*<http://www.linkedin.com/in/stefanoiacovella>
> **http://twitter.com/#!/Iacovellas* <http://twitter.com/#!/Iacovellas>
> 2012/6/14 aborrell <*borrellalex at gmail.com* <borrellalex at gmail.com>>:
> > Hi Paolo, thanks for your post about postgis 2.0. I've been trying to
> install
> > it on an OSGeo 5.5 Ubuntu live dvd installed on a hard disk. I managed to
> > get Postgresql 9.1 working, but when I try to configure Postgis 2.0 I get
> > the following error:
> > ./configure --with-pgconfig=/usr/lib/postgresql/9.1/bin/pg_config
> > --with-geosconfig=/usr/bin/geos-config --with-jsondir=/usr
> --with-topology
> > --with-raster
> > checking libpq-fe.h presence... yes
> > checking for libpq-fe.h... yes
> > checking for PQserverVersion in -lpq... yes
> > checking for xml2-config... /usr/bin/xml2-config
> > checking libxml/tree.h usability... yes
> > checking libxml/tree.h presence... yes
> > checking for libxml/tree.h... yes
> > checking libxml/parser.h usability... yes
> > checking libxml/parser.h presence... yes
> > checking for libxml/parser.h... yes
> > checking libxml/xpath.h usability... yes
> > checking libxml/xpath.h presence... yes
> > checking for libxml/xpath.h... yes
> > checking libxml/xpathInternals.h usability... yes
> > checking libxml/xpathInternals.h presence... yes
> > checking for libxml/xpathInternals.h... yes
> > checking for xmlInitParser in -lxml2... no
> > configure: error: could not find libxml2
> > I can't make it work. xml2-config is in /usr/bin, libxml2 in
> > /usr/include/libxml2/libxml and libxml2.so, libxml2.a in
> > /usr/lib/i386-linux-gnu
> > I would appreciate your help. Thanks
> > Alex Borell
> > Mexico
> > View this message in context: *
> http://postgis.17.n6.nabble.com/Installing-on-Debian-tp4996113p4998272.html
> *<http://postgis.17.n6.nabble.com/Installing-on-Debian-tp4996113p4998272.html>
> > Sent from the PostGIS - User mailing list archive at Nabble.com.
> > postgis-users mailing list
> > *postgis-users at postgis.refractions.net*<postgis-users at postgis.refractions.net>
> > *http://postgis.refractions.net/mailman/listinfo/postgis-users*<http://postgis.refractions.net/mailman/listinfo/postgis-users>
> postgis-users mailing list*
> **postgis-users at postgis.refractions.net*<postgis-users at postgis.refractions.net>
> **http://postgis.refractions.net/mailman/listinfo/postgis-users*<http://postgis.refractions.net/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120618/a5552a4f/attachment.html>
