[postgis-users] Problem compiling PostGIS2.0 with GEOS 1.3.3+
Sandro Santilli
strk at keybit.net
Sun Jun 24 08:43:31 PDT 2012
On Sat, Jun 23, 2012 at 11:20:07AM +0200, Jan Hartmann wrote:
> You are right, it is not from GEOS but from an older PostGIS
> install. Even so, the problem of two versions of liblwgeom.h
> remains. The reason is that liblwgeom.h in /usr/local is only
> updated at "make install". Before that, the compiler sees the older
> version when compiling a new version of PostGIS. But only when there
> is an explicit -I directive for /usr/local/include, *and* that
> directive precedes the include directive for the PostGIS source
> tree.That is not a very common case, it only happens when you
> compile as non-root to non-standard install directories. Even so, it
> would be better to use an explicit path when including liblwgeom.h
> (../liblwgeom.h/liblwgeom.h)
I'd rather make sure -I<localdir> appears first.
Can you handle to do so by tweaking the Makefile.in files ?
Would you file a ticket to handle this ? Thanks !
--strk;
Sent from our free software
http://www.gnu.org/philosophy/free-sw.html
