[postgis-users] windows binaries for rc1 avaialble -- should fix people's issues
George Silva
georger.silva at gmail.com
Thu Mar 29 10:49:35 PDT 2012
I'll test rc1 against W7 tonight and publish the results :D
Cheers!
On Thu, Mar 29, 2012 at 2:32 PM, Paragon Corporation <lr at pcorp.us> wrote:
> All we have windows binaries rc1 up.
> John,
> You were right about the xml. We neglected to package this dll in the
> postgis 2.0.0 experimental builds thinking that EDB builds already had
> them. Theirs has a different name though.
> So I think all people who were installing with on an instance that had
> postgis 1.5. didn't notice it because we distributed that dll with the
> postgis 1.5s.
> We didn't notice the issues until trying ot install on a virgin windows xp
> install. Anyrate the rc1s up should work fine for everythong
> http://www.postgis.org/download/windows/experimental.php
> For people who had issues before, please let us know if you still have
> issues with the rc1 builds.
> Looks like there will be an Rc2 since we've already got fixes up and
> tickets. We;d like as many people testing so we can have a good RC2.
> Thanks,
> Regina
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *John
> Callahan
> *Sent:* Thursday, March 29, 2012 8:54 AM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] Installation problem
> withpostgis-pg91-binaries-2.0.0beta4w32
> I had that problem once. It was related to a missing (or outdated)
> libxml2-2.dll in the /bin folder. I would stop the postgres service and
> try manually recopying all of the files to their appropriate locations.
> - John
> On Thu, Mar 29, 2012 at 6:25 AM, <feurbano at clix.pt> wrote:
>> Dear list,
>> we are trying to install the latest available experimental binaries for
>> windows
>> (postgis-pg91-binaries-2.0.0beta4w32).
>> We installed postgres 9.1 (32bit) and than run the installer file
>> 'makepostgisdb_using_extensions.bat' with the proper (hopefully) set.
>> We get this error:
>> "C:\Program Files (x86)\PostgreSQL\9.1\bin\psql" -d "sam" -c "CREATE
>> EXTENSION
>> postgis;"
>> ERROR: could not load library "C:/Program Files
>> (x86)/PostgreSQL/9.1/lib/postgis-2.0.dll": The specified module could not
>> be found.
>> We are installing on a Windows Server 2008 R2 64-bit and we have installed
>> postgresql-9.1.3-1-windows.exe (32-bit)
>> The file 'makepostgisdb_using_extensions.bat' look like this:
>> REM this is an example of how to create a new db and spatially enable it
>> using
>> CREATE EXTENSION
>> set PGPORT=5432
>> set PGHOST=localhost
>> set PGUSER=postgres
>> set PGPASSWORD=***
>> set THEDB=sam
>> REM PGINSTALL=C:\Program Files\PostgreSQL\9.1
>> set PGINSTALL=C:\Program Files (x86)\PostgreSQL\9.1
>> set PGADMIN=%PGINSTALL%\pgAdmin III
>> set PGBIN=%PGINSTALL%\bin\
>> set PGLIB=%PGINSTALL%\lib\
>> set POSTGISVER=2.0
>> xcopy bin\*.* "%PGBIN%"
>> xcopy /I /S bin\postgisgui\* "%PGBIN%\postgisgui"
>> xcopy /I plugins.d "%PGADMIN%\plugins.d"
>> xcopy lib\*.* "%PGLIB%"
>> xcopy share\extension\*.* "%PGINSTALL%\share\extension"
>> xcopy /I share\contrib\postgis-%POSTGISVER%
>> "%PGINSTALL%\share\contrib\postgis-%POSTGISVER%"
>> "%PGBIN%\psql" -c "CREATE DATABASE %THEDB%"
>> "%PGBIN%\psql" -d "%THEDB%" -c "CREATE EXTENSION postgis;"
>> "%PGBIN%\psql" -d "%THEDB%" -c "CREATE EXTENSION postgis_topology;"
>> REM Uncomment the below line if this is a template database
>> REM "%PGBIN%\psql" -d "%THEDB%" -c "UPDATE pg_database SET datistemplate
>> = true
>> WHERE datname = '%THEDB%';GRANT ALL ON geometry_columns TO PUBLIC; GRANT
>> ALL ON
>> spatial_ref_sys TO PUBLIC"
>> "C:/Program Files (x86)/PostgreSQL/9.1/lib/postgis-2.0.dll" is where it is
>> supposed to be.
>> Any suggestion?
>> Thanks a lot
>> Ferdinando
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
George R. C. Silva
Desenvolvimento em GIS
http://geoprocessamento.net
http://blog.geoprocessamento.net
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120329/69598ff8/attachment.html>
