[postgis-users] windows binaries for rc1 avaialble -- should fix people's issues
Chris English sglish at hotmail.com
Thu Mar 29 13:54:26 PDT 2012
Regina,
Worked great, no snags, going off to wrestle with tiger_geocoder_2010.
Thanks,
Chris English
To: postgis-users at postgis.refractions.net
Date: Thu, 29 Mar 2012 13:32:24 -0400
Subject: Re: [postgis-users] windows binaries for rc1 avaialble -- should	fix people's issues
All we have windows binaries rc1 up.
John,
You were right about the xml.  We neglected to package
this dll in the postgis 2.0.0 experimental builds thinking that EDB builds
already had them.  Theirs has a different name though.
So I think all people who were installing with on an instance
that had postgis 1.5. didn't notice it because we distributed that dll with the
postgis 1.5s.
We didn't notice the issues until trying ot install on a
virgin windows xp install.  Anyrate the rc1s up should work fine for
everythong
http://www.postgis.org/download/windows/experimental.php
For
people who had issues before, please let us know if you still have issues with
the rc1 builds.
Looks
like there will be an Rc2 since we've already got fixes up and tickets.
We;d like as many people testing so we can have a good RC2.
Thanks,
Regina
  postgis-users-bounces at postgis.refractions.net
  [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
  John Callahan
Sent: Thursday, March 29, 2012 8:54
  AM
To: PostGIS Users Discussion
Subject: Re:
  [postgis-users] Installation problem
  withpostgis-pg91-binaries-2.0.0beta4w32
  I had that problem once.  It was related to a missing (or
  outdated) libxml2-2.dll in the /bin folder.  I would stop the postgres
  service and try manually recopying all of the files to their appropriate
  locations.
  - John
  On Thu, Mar 29, 2012 at 6:25 AM, <feurbano at clix.pt> wrote:
  Dear list,
we are trying to install the latest
    available experimental binaries for
    windows
(postgis-pg91-binaries-2.0.0beta4w32).
We installed postgres
    9.1 (32bit) and than run the installer
    file
'makepostgisdb_using_extensions.bat' with the proper (hopefully)
    set.
We get this error:
"C:\Program Files
    (x86)\PostgreSQL\9.1\bin\psql"  -d "sam" -c "CREATE
    EXTENSION
postgis;"
ERROR:  could not load library "C:/Program
    Files
(x86)/PostgreSQL/9.1/lib/postgis-2.0.dll": The specified module
    could not be found.
We are installing on a Windows Server 2008 R2
    64-bit and we have installed
postgresql-9.1.3-1-windows.exe
    (32-bit)
The file 'makepostgisdb_using_extensions.bat' look like
    this:
REM this is an example of how to create a new db and spatially
    enable it using
CREATE EXTENSION
set PGPORT=5432
set
    PGHOST=localhost
set PGUSER=postgres
set PGPASSWORD=***
set
    THEDB=sam
REM PGINSTALL=C:\Program Files\PostgreSQL\9.1
set
    PGINSTALL=C:\Program Files (x86)\PostgreSQL\9.1
set
    PGADMIN=%PGINSTALL%\pgAdmin III
set PGBIN=%PGINSTALL%\bin\
set
    PGLIB=%PGINSTALL%\lib\
set POSTGISVER=2.0
xcopy bin\*.*
    "%PGBIN%"
xcopy /I /S bin\postgisgui\* "%PGBIN%\postgisgui"
xcopy /I
    plugins.d "%PGADMIN%\plugins.d"
xcopy lib\*.* "%PGLIB%"
xcopy
    share\extension\*.* "%PGINSTALL%\share\extension"
xcopy /I
    share\contrib\postgis-%POSTGISVER%
"%PGINSTALL%\share\contrib\postgis-%POSTGISVER%"
"%PGBIN%\psql"
     -c "CREATE DATABASE %THEDB%"
"%PGBIN%\psql"  -d "%THEDB%" -c
    "CREATE EXTENSION postgis;"
"%PGBIN%\psql"  -d "%THEDB%" -c "CREATE
    EXTENSION postgis_topology;"
REM Uncomment the below line if this is
    a template database
REM "%PGBIN%\psql" -d "%THEDB%" -c "UPDATE
    pg_database SET datistemplate = true
WHERE datname = '%THEDB%';GRANT ALL
    ON geometry_columns TO PUBLIC; GRANT ALL ON
spatial_ref_sys TO
    PUBLIC"
"C:/Program Files
    (x86)/PostgreSQL/9.1/lib/postgis-2.0.dll" is where it is
supposed to
    be.
Any suggestion?
Thanks a
    lot
Ferdinando
postgis-users
http://postgis.refractions.net/mailman/listinfo/postgis-users
postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120329/8b1b406e/attachment.html>
