[postgis-users] PostGIS 2.0 instalation problem
Paragon Corporation lr at pcorp.us
Wed May 2 20:32:06 PDT 2012
Yap definitely works on windows xp.  I just tried uninstalling my 9.1.3 on
windows xp , reinstalling and then using application stack builder to
install PostGIS 2.0.0 and it worked fine.
Regarding dependency walker -- if you still have problems -- there is a
setting in dependency walker that lets you add a search directory.  You'll
want ot add the C:\program files\postgresql\9.1\bin folder for it to
correctly resolve the dependencies.
The only dependency I can think of we have aside from what we package and
what EDB packages is the
MSVCRT.dll
I've never seen a windows computer without that file though so haven't
bothered distributing it and it's usually located in system32, but htere
could be an incompatbility there which dependency walker might not pick up.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of wobo
> Sent: Wednesday, May 02, 2012 6:49 PM
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] PostGIS 2.0 instalation problem
> Thanks for the quick response.
> First I succesfully installed PostgreSQl 9.1.3 using the win
> x86-32 installer from
> http://www.enterprisedb.com/products-services-training/pgdownl
oad#windows
oad#windows .
> I was able to create extensions like adminpack so I guess
> postgresql looks fine.
> Then I tried to install PostGIS 2.0 using the Application
> Stack Builder that came along the install. But it failed and
> an error appeared. The PostGIS installer
> (postgis-pg91-setup-2.0.0-3.exe) gave the same error.
> http://postgis.17.n6.nabble.com/file/n4947700/pg.jpg
> Afterwards I downloaded the postgis-pg91-binaries-2.0.0w32-2
> (zip) file, copied the content by hand to the right
> directories (~ xcopy lines in makepostgisdb.bat). libxml2-2,
> libGEOS, etc are in the PGBIN folder. Indeed I was first
> mistakenly using the 64-bit installer.. but using the 32-bit
> installer afterwards didn't solve the problem.
> Since you mention it should work fine with Windows XP I will
> test it again tomorrow. First I'll uninstall postgresql,
> remove the postgres user, remove the data folder and delete
> the registry (regedit) for postgresql. Anything else I forgot
> to start a clean install?<br>
> Tomorrow I'll keep you posted about the second install attempt.
> Wouter
> http://postgis.17.n6.nabble.com/PostGIS-2-0-instalation-proble
m-tp4624902p4947700.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
