[postgis-users] Very large WHERE clause?
mark wynter mark at dimensionaledge.com
Mon May 7 16:15:11 PDT 2012
As an alternative, you could use PL/pgSQL to create a custom function, and
then pass one (or more) arguments to the query's "WHERE" clause dynamically.
At the application level, this would allow users for example to <select>
from a form, where the select <options> are populated using the results of a
SELECT DISTINCT query.
View this message in context: http://postgis.17.n6.nabble.com/Very-large-WHERE-clause-tp4952906p4959028.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
