[postgis-users] error with installation of postgis1.5 on Windows 7- please help
Paragon Corporation lr at pcorp.us
Mon May 14 01:11:52 PDT 2012
Mary,
Unfortuantely I don't have a 8.3 handy around to test with at the moment
though I will soon.  The libiconv-2.dll is sometimes present and sometimes
not and the installer should skip it if its already present.  I'll double
check to make sure we didn't mess that up when packaging last.
Regarding the
http://ftp.postgresql.org/pb/projects/pgFoundry/stackbuilder/postgis-pg83-se
tup-1.5.3-2.exe
I'll check with Dave Page on that.  That one is a distribution network
issue.
 Regarding using 8.3 verses a newer version of PostgreSQL.  We build the
windows installers for 1.5 for 8.4,9.0, and 9.1 as well so not wanting to
move to 2.0 shouldn't stop you from using
a newer version of PostgreSQL.  I would at least go with 8.4 since 8.3 will
be out of support in a year or less and I don't recall there being any
issues with going from 8.3 to 8.4
You would simply just restore your backup on the new PostgreSQL 8.4 and
things should just work (if you had the same 1.5 on your old machine)
You might have to run the 1.5 minor upgrade script but that should be all.
BTW: we also have the 1.5.4 binaries up too --
http://www.postgis.org/download/windows/#windbinaries
But we haven't finished packaging the installers yet.  To use the binaires,
you just need to extract the files into your PostgreSQL install folder and
run the batch script with the relevant settings.
Hope that helps,
Regina
http://www.postgis.us
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mary
O'Brien
Sent: Monday, May 14, 2012 3:41 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] error with installation of postgis1.5 on Windows 7-
please help
Hi
I'm trying to install postGIS on Windows 7 and keep getting an installation
error.
"Error opening file for writing: C:\Program Files
(x86)\PostgresQL\8.3\bin\libiconv-2.dll"
The file libiconv-2.dll exists at this location.
I've installed postgresql8.3 (postgresql-8.3.18-1-windows.exe) and now
installing postgis1.3 or 1.4 or 1.5 (I've tried them all) from the
Application Stack Builder, and each time get the error " Failed to open
tup-1.5.3-2.exe   Error: The file does not exist"
So I've downloaded the postgis installer postgis-pg83-setup-1.5.3-2.exe and
tied to install this separately. I then get the error "Error opening file
for writing: C:\Program files (x86)\PostgresQL\8.3\bin\libiconv-2.dll"
I'm running the installers as Administrator (using the right click/ Run as
Administrator option in Windows 7.
I've also tried logging in with administrator login and installing - again
the same errors.
I'm installing postgres8.3 and postgis1.5 as this is what I had running on
my old machine, and I'm trying to replicate. The metadata seems to be stored
in views not tables within the new postgresql 9.1 - not what I want at the
moment.
Has anyone experienced this?
Any ideas on why the install keeps erroring?
Your help much appreciated.
Thanks
Mary
 <http://www.1spatial.com/services/consulting/data_improvement_process>
1Spatial: Steering you towards efficient and reliable location-based data
with the 1Spatial Data Improvement Process
1Spatial Group Limited; Registered in England No. 4785688 VAT Reg. No.
816329821; Registered Office: Tennyson House; Cambridge Business Park;
Cambridge; CB4 0WZ; United Kingdom
IMPORTANT NOTICE
This e-mail and any files transmitted with it are confidential and intended
solely for the use of the individual or entity to whom they are addressed.
If you have received this e-mail in error please notify the sender
immediately and delete this e-mail from your system. Please note that any
views or opinions presented in this e-mail are solely those of the author
and do not necessarily represent those of 1Spatial Group Limited, its
subsidiaries or associated companies, except where the author specifically
states them to be the views of 1Spatial Group Limited, its subsidiaries or
associated companies.
1Spatial Group Limited, its subsidiaries and associated companies will not
be held liable for any legally binding obligations that are not the subject
of an official 1Spatial purchase order or as part of a contract signed by a
director of one of the aforementioned companies.
Although the company has taken reasonable precautions to ensure no viruses
are present in this email, the company cannot accept responsibility for any
loss or damage arising from the use of this email or attachments. You should
understand and accept that, when communicating with us by e-mail, it is not
a totally secure communications medium.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120514/e5a1adf7/attachment.html>
