[postgis-users] Topology Postgis 2.0
Sandro Santilli strk at keybit.net
Fri Oct 5 10:42:50 PDT 2012
On Thu, Oct 04, 2012 at 04:39:49PM +0200, Sandro Santilli wrote:
> On Thu, Oct 04, 2012 at 07:11:47AM -0700, ps.tiara wrote:
> > Hi, it's me again..
> > I have installed Postgis 2.0.1 and the function of toTopoGeom has worked...
> > I used toTopogeom for multilinestring (2d & 3d)  geometry and it worked..
> > It also worked for  polygon 3d geometry...but it didn't work for
> > multipolygon 3d..
> > Here is the message error :
> > update public.phtomulti_srid
> > set topo = topology.toTopoGeom(geom,'phtomulti_topo',1,0.0000001)
> > where id='1';
> > ERROR:  Column has Z dimension but geometry does not
> > CONTEXT:  SQL statement "INSERT INTO phtomulti_topo.node(node_id, geom)
> >     VALUES(26,'0101000020E61000000000000000000000000000000000F03F')"
> Could you please send a self-contained script showing the problem ?
> It should include the CreateTopology call and the literal value of
> the geometry where id = 1.
I did it: http://trac.osgeo.org/postgis/ticket/2033
--strk;
 http://www.cartodb.com - Map, analyze and build applications with your data
                                       ~~ http://strk.keybit.net
