[postgis-users] st_closespoint weridness
Nicklas Avén nicklas.aven at jordogskog.no
Fri Oct 5 12:40:53 PDT 2012
I am not sure I understand what you get and what you expect.
Is your input point inside the polygon?
Regards
Nicklas
On Fri, 2012-10-05 at 20:10 +0100, Dave Potts wrote:
> just tried a
> select st_closestpoint(poly,point) and got the result point
> The point is within a the closed polygon poly, the version is postgis 2.0
> is there any sane reason why this behave in this manner.  I had expected
> to the value of the x/y coordinate pair from the polylgon that is nearest
> to point, not the value of point!
> Any suggestions as what I might be doing wrong?  or an suggestions for a
> better way of doing this?
> regards
> Dave.
