[postgis-users] Pg_wrapper error
José Pedro Santos zpsantos1 at hotmail.com
Fri Oct 26 07:51:57 PDT 2012
> Date: Fri, 26 Oct 2012 10:41:42 -0400
> From: Lee.Hachadoorian+L at gmail.com
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] Pg_wrapper error
> On Thu, Oct 25, 2012 at 11:26 AM, José Pedro Santos
> <zpsantos1 at hotmail.com> wrote:
> > Dear all,
> > I have one problem when I try to load raster to Postgis with the script
> > raster2pgsql from the shell.
> > I have this error: Error: pg_wrapper: invalid command name
> > Before this error (I have Postgis version 2.0) I can't use the command
> > (raster2pgsql) in the shell (was not found) but i enable it with this
> > expression:
> > sudo ln -sf /usr/share/postgresql-common/pg_wrapper /usr/bin/raster2pgsql
> > After that the error about pg_wrapper appear.
> > Any suggestion?
> > Best Regards and thanks,
> > Jose Santos
> raster2pgsql and shp2pgsql are not links to pg_wrapper. The error you
> are getting is exactly what I get if I try to call pg_wrapper
> directly, but raster2pgsql works because it is installed and exists as
> an executable in /usr/bin.
> Remove the link to pg_wrapper figure out why raster2pgsql isn't
> installed. How did you install PostGIS 2? What OS? Is shp2pgsql
> installed and working? If it is, is raster2pgsql available in the same
> directory? etc.
> --Lee
> Lee Hachadoorian
> Asst Professor of Geography, Dartmouth College
> http://freecity.commons.gc.cuny.edu/
raster2pgsql don't work also shp2pgsql don't work (I have the Postgis 2.0 installed in Ubuntu 12.04). I just enable the function but seems that the pg_wrapper don't work.
I have all the raster2... and shp2... in /usr/bin but don't work when I try to call them in the shell.
Any idea?
Regards,
JSantos
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121026/daa41972/attachment.html>
