[postgis-users] Noob question with shp2pgsql
David Rush
david at rushtone.com
Fri Apr 12 15:14:22 PDT 2013
Total noob to PostgreSQL and PostGIS here. Trying to follow examples from
the Obe+Hsu book (1st Ed) in using shp2pgsql from the command line to
import some tiger county data.
I ran this:
shp2pgsql -s 4269 -g geom_4269 -W LATIN1
c:/users/david/downloads/tl_2012_us_county/tl_2012_us_county.shp
public.us_counties psql -h localhost -U postgres -p 5432 -d mygisdb
Thanks to an archive of this list that led me to add the "-W LATIN1" param
(it was failing with an error w/out it).
Now the command runs for several minutes, spitting out mostly zillions of
hex digits, with no overt errors. Last line it spits out is "COMMIT;".
But when I go into psql, I can't find the public.us_counties table that I
thought I just added created:
mygisdb=# select * from public.us_counties;
ERROR: relation "public.us_counties" does not exist
LINE 1: select * from public.us_counties;
mygisdb=# select table_schema, table_name,table_type from
information_schema.tables where
table_schema not in ('pg_catalog','information_schema');
table_schema | table_name | table_type
public | geography_columns | VIEW
public | geometry_columns | VIEW
public | spatial_ref_sys | BASE TABLE
ch01 | lu_franchises | BASE TABLE
ch01 | fastfoods | BASE TABLE
(5 rows)
Poking around with pgAdmin III I can't find in anywhere, either.
Is the new table us_counties hiding somewhere? Or did it quietly fail? Or
what?
David
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130412/60722d18/attachment.html>
