[postgis-users] Noob question with shp2pgsql
pcreso at pcreso.com
Fri Apr 12 15:25:24 PDT 2013
Hi David,
Are you familiar with the terms STDIN & STDOUT?
They are the system devices for input & output.
shp2pgsql sends its output to STDOUT which is generally the screen - standard output device. So what you see on screen is what you want to send to the database - all the commands to create the appropriate table and insert the shapefile data in the new table.
What you need to do is redirect the STDOUT content to the database instead, done easily enough by adding a "|" (pipe) character before your psql command. This redirects the shp2pgsql output to become input to the psql command instead of sending it to the screen.
so your command becomes:
shp2pgsql -s 4269 -g geom_4269 -W LATIN1
c:/users/david/downloads/tl_2012_us_county/tl_2012_us_county.shp
public.us_counties | psql -h localhost -U postgres -p 5432 -d mygisdb
Cheers,
Brent Wood
--- On Sat, 4/13/13, David Rush <david at rushtone.com> wrote:
Subject: [postgis-users] Noob question with shp2pgsql
To: postgis-users at lists.osgeo.org
Date: Saturday, April 13, 2013, 10:14 AM
Total noob to PostgreSQL and PostGIS here. Trying to follow examples from the Obe+Hsu book (1st Ed) in using shp2pgsql from the command line to import some tiger county data.
I ran this:
shp2pgsql -s 4269 -g geom_4269 -W LATIN1 c:/users/david/downloads/tl_2012_us_county/tl_2012_us_county.shp public.us_counties psql -h localhost -U postgres -p 5432 -d mygisdb
Thanks to an archive of this list that led me to add the "-W LATIN1" param (it was failing with an error w/out it).
Now the command runs for several minutes, spitting out mostly zillions of hex digits, with no overt errors. Last line it spits out is "COMMIT;".
But when I go into psql, I can't find the public.us_counties table that I thought I just added created:
mygisdb=# select * from public.us_counties;
ERROR: relation "public.us_counties" does not existLINE 1: select * from public.us_counties; ^mygisdb=# select table_schema, table_name,table_type from information_schema.tables where
table_schema not in ('pg_catalog','information_schema'); table_schema | table_name | table_type--------------+-------------------+------------ public | geography_columns | VIEW
public | geometry_columns | VIEW public | spatial_ref_sys | BASE TABLE ch01 | lu_franchises | BASE TABLE ch01 | fastfoods | BASE TABLE
(5 rows)
Poking around with pgAdmin III I can't find in anywhere, either.
Is the new table us_counties hiding somewhere? Or did it quietly fail? Or what?
David
-----Inline Attachment Follows-----
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130412/0c5caa8e/attachment.html>
