[postgis-users] Cut lat/lon to six decimal digits
Carsten Hogertz carsten.hogertz at gmail.com
Tue Apr 16 07:22:01 PDT 2013
Perfect! Thank you guys.
Carsten
2013/4/16 Hugues François <hugues.francois at irstea.fr>
> And what about round(st_y(geom)::numeric, 6) ?
> Hug
> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Carsten Hogertz
> *Sent:* Tuesday, April 16, 2013 4:05 PM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] Cut lat/lon to six decimal digits
>  Thanks.
> Indead I did. I also tried
> trunc(ST_Y(geom), 6)
> But it gives back:
> Function round(double precision, integer) does not exist
>> Hello,
>> Did you simply try
>> round(ST_Y(geom), 6) as lat
>> round(ST_X(geom), 6) as lon
>> Hugues.
>> *Sent:* Tuesday, April 16, 2013 3:51 PM
>> *Subject:* [postgis-users] Cut lat/lon to six decimal digits
>>   Hi everyone,
>> I've got the following SQL to extract the lat/lon of a polygone:
>> SELECT
>> ROW_NUMBER () over () as id,
>> name,
>> geom,
>> ST_Y(geom) as lat,
>> ST_X(geom) as lon
>> FROM (SELECT name, (ST_DumpPoints(geom)).* FROM timezones20032013) as foo
>> It gives me back the lat and lon as a number with a lot of digits, e.g.:
>> 42.4734992980957
>> 1.71096694469452
>> Instead what I need is:
>> 42.473499
>> 1.710967
>> How could I change my SQL to get the result cut/rounded?
>> Any help would be appreciated.
>> Thanks in advance
>> Carsten
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130416/9bd0e7fb/attachment.html>
