[postgis-users] Cut lat/lon to six decimal digits
Martin Feuchtwanger
feumar at shaw.ca
Tue Apr 16 10:00:57 PDT 2013
If you're really concerned about output format, rather than the actual
value, consider the *to_char*() function:
select to_char (42.4734992980957, '999D999999')
--> " 42.473499"
where you also get right justification for free.
Martin Feuchtwanger feumar at shaw.ca 604-254-0361
Vancouver, BC V5N 1J6
http://members.shaw.ca/geomatics.developer
On 16/04/2013 7:22 AM, Carsten Hogertz wrote:
> Perfect! Thank you guys.
> Carsten
> 2013/4/16 Hugues François <hugues.francois at irstea.fr
> <mailto:hugues.francois at irstea.fr>>
> And what about round(st_y(geom)::numeric, 6) ?
> *From:* postgis-users-bounces at lists.osgeo.org
> <mailto:postgis-users-bounces at lists.osgeo.org>
> [mailto:postgis-users-bounces at lists.osgeo.org
> <mailto:postgis-users-bounces at lists.osgeo.org>] *On Behalf Of
> *Carsten Hogertz
> *Sent:* Tuesday, April 16, 2013 4:05 PM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] Cut lat/lon to six decimal digits
> Thanks.
> Indead I did. I also tried
> trunc(ST_Y(geom), 6)
> But it gives back:
> Function round(double precision, integer) does not exist
> Did you simply try
> round(ST_Y(geom), 6) as lat
> round(ST_X(geom), 6) as lon
> *Carsten Hogertz
> *Sent:* Tuesday, April 16, 2013 3:51 PM
> *Subject:* [postgis-users] Cut lat/lon to six decimal digits
> Hi everyone,
> I've got the following SQL to extract the lat/lon of a polygone:
> SELECT
> ROW_NUMBER () over () as id,
> name,
> geom,
> ST_Y(geom) as lat,
> ST_X(geom) as lon
> FROM (SELECT name, (ST_DumpPoints(geom)).* FROM
> timezones20032013) as foo
> It gives me back the lat and lon as a number with a lot of
> digits, e.g.:
> 42.4734992980957
> 1.71096694469452
> Instead what I need is:
> 42.473499
> 1.710967
> How could I change my SQL to get the result cut/rounded?
> Any help would be appreciated.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130416/42a3d173/attachment.html>
