[postgis-users] ST_RotateX with pointOrigin!
Stephen Mather
stephen at smathermather.com
Sun Dec 15 11:15:21 PST 2013
Awesome. I'll take a look.
On Sun, Dec 15, 2013 at 1:29 PM, Bborie Park <dustymugs at gmail.com> wrote:
> Start in the regress directory found in the root of the postgis source.
> You'll see that there are always two files for any particular test
> (MYTEST.sql and MYTEST_expected). To include MYTEST as part of "make
> check", you add MYTEST to regress/Makefile.in
> -bborie
> On Sat, Dec 14, 2013 at 10:29 PM, Stephen Mather <
> stephen at smathermather.com> wrote:
>> I have ticketed. It's a little messy of a ticket (actually two), so
>> apologies for that.
>> http://trac.osgeo.org/postgis/ticket/2570
>> http://trac.osgeo.org/postgis/ticket/2571
>> I have not yet written any unit tests. Where would I begin...
>> On Sun, Dec 15, 2013 at 1:02 AM, Bborie Park <dustymugs at gmail.com> wrote:
>>> Sweet. Can you create a ticket and attach the patch?
>>> Some unit tests would be nice so that expected behavior is maintained...
>>> and bugs are caught.
>>> Thanks!
>>> -bborie
>>> On Sat, Dec 14, 2013 at 7:57 PM, Stephen Mather <
>>>> Ahem-- bugs fixed:
>>>> -- Function: st_rotatex(geometry, double precision, geometry)
>>>> CREATE OR REPLACE FUNCTION ST_RotateX(geomA geometry, rotRadians
>>>> double precision, pointOrigin geometry)
>>>> RETURNS geometry AS
>>>> $BODY$
>>>> ----- Transform geometry to nullsville (0,0,0) so rotRadians will take
>>>> place around the pointOrigin
>>>> WITH transformed AS (
>>>> SELECT ST_Translate(geomA, -1 * ST_X(pointOrigin), -1 *
>>>> ST_Y(pointOrigin), -1 * ST_Z(pointOrigin)) AS the_geom
>>>> ----- Rotate in place
>>>> rotated AS (
>>>> SELECT ST_RotateX(the_geom, rotRadians) AS the_geom FROM transformed
>>>> ----- Translate back home
>>>> rotTrans AS (
>>>> SELECT ST_Translate(the_geom, ST_X(pointOrigin),
>>>> ST_Y(pointOrigin), ST_Z(pointOrigin)) AS the_geom
>>>> FROM rotated
>>>> ----- profit
>>>> SELECT the_geom from rotTrans
>>>> $BODY$
>>>> LANGUAGE sql VOLATILE
>>>> COST 100;
>>>> On Sat, Dec 14, 2013 at 8:37 PM, Stephen Mather
>>>> <stephen at smathermather.com> wrote:
>>>> > Hi All,
>>>> > I think I avoided doing linear algebra, which is good since I never
>>>> > studied it... .
>>>> > This is my cludgy patch for making a version of
>>>> > geometry ST_RotateX(geometry geomA, float rotRadians, geometry
>>>> pointOrigin)
>>>> > It's not pretty enough to be a real patch ('cause my brain couldn't do
>>>> > that whole linear algebra thing, and hence why it's here and not the
>>>> > developers list), but thought I'd share it anyway and get impressions,
>>>> > and have some brighter minds make sure I don't have some major logic
>>>> > failure here:
>>>> > DROP FUNCTION st_rotatex(geometry,double precision,geometry);
>>>> > RETURNS geometry AS
>>>> > $BODY$
>>>> > rotated AS (
>>>> > SELECT ST_RotateX(the_geom, rotRadians) FROM transformed
>>>> > rotTrans AS (
>>>> > SELECT ST_Translate(geomA, ST_X(pointOrigin), ST_Y(pointOrigin),
>>>> > ----- profit
>>>> > $BODY$
>>>> > COST 100;
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131215/de56b8be/attachment.html>
