[postgis-users] Old question resurfacing
Frank Henze henze at tu-cottbus.de
Sun Dec 15 12:10:11 PST 2013
I dont know, at which point the downsampling should take place.
An interesting solution for webbased visualization could be XB Point Stream:
http://zenit.senecac.on.ca/wiki/index.php/XB_PointStream
Frank
Am 15.12.2013 00:45, schrieb Rémi Cura:
> I guess everybody has reached the same conclusion :
> using pointcloud is is possible to manage 100's of billions of points
> and retrieve quickly those of interest.
> Now most of the usage requiere severe downsampling, which isn't a part
> of anything yet but may come (I'm working on adding this to pointcloud).
> Cheers,
> Rémi-C
> 2013/12/12 Basques, Bob (CI-StPaul) <bob.basques at ci.stpaul.mn.us
> <mailto:bob.basques at ci.stpaul.mn.us>>
>     Frank,
>     I don't know about a group, or for that matter centering it on just
>     PostGIS, but I see 3D as the next big Mapping product line that
>     people are going to be looking for.  PostGIS is a piece in a bigger
>     puzzle.  I've been researching different methods for storing and
>     segmenting the point cloud data on the server side for a while now
>     and PostGIS has percolated up to near the top of the list.
>     There is a big piece related in how to generalize data for 3D
>     scaling in the browser, that's the biggest shortcoming I've become
>     aware of in order to make something run nicely in the browser, I've
>     also of late been forcing myself to think mobile, which has it's own
>     set of criteria as far as the browser goes.
>     I would likely join the list of something call PostGIS 3d, but I
>     don't know that there is enough interest for a whole community
>     (yet), maybe it's better to stay ahead of the curve though.
>     Bobb
>     -----Original Message-----
>     From: postgis-users-bounces at lists.osgeo.org
>     <mailto:postgis-users-bounces at lists.osgeo.org>
>     [mailto:postgis-users-bounces at lists.osgeo.org
>     <mailto:postgis-users-bounces at lists.osgeo.org>] On Behalf Of Frank Henze
>     Sent: Thursday, December 12, 2013 1:17 PM
>     To: PostGIS Users Discussion
>     Subject: Re: [postgis-users] Old question resurfacing
>     Hi all,
>     briefly a few details to http://www2.htw-dresden.de/~s68071/3DWebGIS/:
>     - Projektauswahl: Baalbek  and  Palatin  are static X3D models (no
>     PostGIS)
>     - Projektauswahl: W3DS   is dynamically generated from a PostGIS 2.0 DB
>     via a "GetScene"-request by Geoserver
>     I think Baalbek is too large (too many triangles) and therefore
>     possibly leads to crash. Palatin and W3DS should work.
>     The 3D window is a standard WebGL window based on X3DOM. So it
>     should run right stable.
>     Once again my question:
>     Is there an interest in a PostGIS 3D group?
>     Frank
>     Am 12.12.2013 16:55, schrieb Basques, Bob (CI-StPaul):
>      > Frank,
>      > Very nice.  It froze up for me pretty quickly, I tried both FF
>     and Chrome.  Still looked good while it ran.
>      > This stability aspect is a big piece of being able to make
>     something that folks will want to use.  Data segregation will be a
>     big piece moving forward I think.
>      > Bobb
>      > Henze
>      > Sent: Thursday, December 12, 2013 6:04 AM
>      > Hi Bobb,
>      > hi all,
>      > https://hub.sharedgeo.org/apps/x3d/ looks great!
>      > We have similar requirements for a 3d WebGIS.
>      > A first prototype you can find at:
>      > For "Projektauswahl:" select "W3DS"
>      > and then select "Historische Gebäude" (Historical Buildings)
>      > If there is nothing to see, then press on the left side "Alles
>     anzeigen"
>      > We use the community buildt Geoserver incl. Web 3D service +
>     X3DOM + JS.
>      > Some of our problems:
>      > How to import 3D geometries into PostGIS?
>      > Which formats and interfaces (CAD, X3D)?
>      > Point clouds in PostGIS (also import of).
>      > Is there a 3D PostGIS interest-group?
>      > If not, should one established?
>      > Frank
>      > Am 11.12.2013 17:44, schrieb Basques, Bob (CI-StPaul):
>      >> All,
>      >> Nothing that far along.  Did a couple of proofs of concept so far,
>      >> I've done a couple of presentations on the Visualizer approach.  We
>      >> tried a couple of different things, x3Dom, allover'js
>      >> You can see some of them here ( some of the  pages take a while to
>      >> load the data in the background, be patient):
>      >> https://hub.sharedgeo.org/apps/x3d/  (these will generally need a
>      >> webGL enabled browser)
>      >> These are purely intended as a test of just how much data could
>      >> easily be squished into the browser before if blows, so you
>     might experience
>      >> some failures.   Ideally the data coming into these would be
>     segmented
>      >> via a SQL call to PostGIS Pointcloud sources.
>      >> The last two in the list are using some point clouds cut from our
>      >> recent data collect at 8pt per sq meter for the City (6 billion
>      >> points in all), these are using about 300k points each for example.
>      >> Bobb
>      >> *From:*postgis-users-bounces at lists.osgeo.org
>     <mailto:postgis-users-bounces at lists.osgeo.org>] *On Behalf Of *Rémi
>      >> Cura
>      >> *Sent:* Wednesday, December 11, 2013 10:08 AM
>      >> *To:* PostGIS Users Discussion
>      >> *Subject:* Re: [postgis-users] Old question resurfacing
>      >> I would be very interested to know any attempt to visualize 3D point
>      >> cloud from data base !
>      >> We did the same but our solution is far from perfect.
>      >> Bob, is you rporject public/open source, have you any paper/doc
>       about it ?
>      >> Cheers,
>      >> Rémi-C
>      >> 2013/12/11 Basques, Bob (CI-StPaul) <bob.basques at ci.stpaul.mn.us
>     <mailto:bob.basques at ci.stpaul.mn.us>>>
>      >> Hmm,
>      >> I'm working with the Minneapolis International Airport (MSP) on a
>      >> project, any chance that  data is open/accessible enough to play
>     with?
>      >> This could tie directly into a project I'm already working on.
>      >> Thanks
>      >> Bobb
>     <mailto:postgis-users-bounces at lists.osgeo.org>>
>     <mailto:postgis-users-bounces at lists.osgeo.org>>] *On Behalf Of *Gerry
>      >> Creager - NOAA Affiliate
>      >> *Sent:* Tuesday, December 10, 2013 2:14 PM
>      >> Bob, all:
>      >> I agree. I'll have to spend some time with pointcloud but it DOES
>      >> look very promising.
>      >> Another application? Lidar. Pointed at the sky, not at the
>     ground (we
>      >> use 'em to determine cloud layers [ceiling] and sky cover at
>     airports
>      >> for aviation data...).
>      >> Thanks, all!
>      >> gerry
>      >> On Tue, Dec 10, 2013 at 1:49 PM, Basques, Bob (CI-StPaul)
>     <mailto:bob.basques at ci.stpaul.mn.us>>> wrote:
>      >> Gerry,
>      >> Remi's idea about using a point cloud may be spot on for your use.
>      >> It allows you to set a point cloud down to a revolution if need be,
>      >> which seems like what you are looking for..  If the data becomes too
>      >> massive for insertion into DB at real-time speeds, then you could
>      >> also separate this revolution into separate DB's as well, you could
>      >> separate a whole number of ways, by elevation, or quadrant, or . . .
>      >> I'm very interested in visualization possibilities with something
>      >> like this being available in a database.  We're doing some
>     similar db
>      >> 3d visualization stuff on some rather dense point clouds.  Your data
>      >> once available could use the same visualizer.
>      >> Bobb
>      >> *Sent:* Tuesday, December 10, 2013 1:41 PM
>      >> Bob
>      >> At least preliminarily, I can post-process, so speed of db adds
>     isn't
>      >> too troubling. Maintaining accurate representation of the bin-volume
>      >> data is, however, important.
>      >> Typical rotation is 1-3 RPM, and a complete volume scan takes
>     ~11 min
>      >> in clear air (where you best see biologicals if so inclined) or ~5
>      >> min in one of the storm data collection modes. These are for common
>      >> WSR88D, stationary radars. SMARTR's and others we have here that are
>      >> mobile present a whole host of other options/data eval and speed
>     problems.
>      >> Current radar data are nominally considered to have a horizontal
>      >> resolution of ~250 m, ignoring distortion or keyholing due to
>      >> range.Typically 16 elevations are scanned, once or or twice in storm
>      >> mode and a few less elevations in clear air mode.
>      >> Now, the interesting thing that's on the horizon is Phased Array
>     Radar.
>      >> When that happens, more data, more resolution, and faster updates.
>      >> gerry
>      >> On Tue, Dec 10, 2013 at 11:05 AM, Basques, Bob (CI-StPaul)
>      >> Gerry,
>      >> Seems like the biggest hangup would be in adding the data to the DB
>      >> fast enough.  How many points, per revolution, and what is the
>      >> frequency of a revolution (stationary Radar, correct, although as I
>      >> think about it, it could be mobile if needed, just need to add
>     in the
>      >> radar location to each record)?
>      >> Bobb
>      >> *Sent:* Tuesday, December 10, 2013 10:52 AM
>      >> *Subject:* [postgis-users] Old question resurfacing
>      >> I asked this years ago, and I think Paul was less than pleased with
>      >> me (:-), but:
>      >> Has anyone, in the ensuing years looked at encoding radar data
>     into a
>      >> postGIS database? We've a little idea that might benefit one
>     project,
>      >> and getting the radar data into a good geospatial format would be
>      >> beneficial.The data, of coure, would start out as
>     radial-distance and
>      >> intensity from the radar site, although we could preprocess it
>     by gridding.
>      >> Thanks, Gerry
>      >> Gerry Creager
>      >> NSSL/CIMMS
>      >> 405.325.6371 <tel:405.325.6371>
>      >> "Big whorls have little whorls,
>      >> That feed on their velocity;
>      >> And little whorls have lesser whorls,
>      >> And so on to viscosity."
>      >> Lewis Fry Richardson (1881-1953)
>      >> _______________________________________________
>      >> postgis-users mailing list
>      >> postgis-users at lists.osgeo.org
>     <mailto:postgis-users at lists.osgeo.org>
>     <mailto:postgis-users at lists.osgeo.org>>
>      >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>      >> Gerry Creager
>      >> NSSL/CIMMS
>      >> Gerry Creager
>      >> NSSL/CIMMS
>      >> 405.325.6371
>      >> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
