[postgis-users] ST_RotateX with pointOrigin!
Mike Toews
mwtoews at gmail.com
Mon Dec 16 09:52:18 PST 2013
On 15 Dec 2013 21:50, "Stephen Mather" <stephen at smathermather.com> wrote:
> Hmm, I know so little about Euler, strike, dip and rake. What are the
advantages?
Euler angles are very well known, and have a wide range of applications[1].
Strike, dip and rake[2,3] are familiar to any geology student, and also
have a wide range of applications in the earth sciences. They are similar
to Euler angles. I still need to think this one through.
Both of these advanced 3d rotations can be described as affine
transformation parameters. Their advantages are to perform a rigid body
transform using well known angles. I think the XYZ rotation technique you
are describing requires calculations of the X and Y rotation components
(unless the rotation happens to align with the grid, i.e. orthogonal).
> What I do know is that it's easy now to construct a 3 axis rotation
function (which also might be better handled with ST_Affine).
Easy, yes, but I'm not convinced they are useful, or even being used by
othets due to their orthogonal limitations.
-Mike
[1] https://en.wikipedia.org/wiki/Euler_angles
[2] https://en.wikipedia.org/wiki/Strike_and_dip
[3] https://en.wikipedia.org/wiki/Rake_(geology)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131217/ba0339c4/attachment.html>
