[postgis-users] GeometryCollection with GEOMETRYCOLLECTIONM, POINTM etc.. value in constructor.
Baris Ergun barisergun75 at gmail.com
Wed Dec 18 00:53:29 PST 2013
Exactly correct. I also tried to tell that the problem was originated from
org.postgis.GeometryCollection constructor. So I posted to here to
understand why constructor was behaving like this. This constructor is in
postgis-jdbc.jar . Anyone knowing about this problem on
the org.postgis.GeometryCollection constructor?
On 18 December 2013 10:35, Rémi Cura <remi.cura at gmail.com> wrote:
> Hey,
> using this in sql :
> SELECT ST_AsText(ST_GeomFromText(
> 'GEOMETRYCOLLECTIONM(
> POINTM(10 10 100),
> LINESTRINGM(0 50 100, 100 50 100),
> POLYGONM((25 25 100,75 25 100,75 75 100,25 75 100,25 25 100),(45 45 100,55
> 45 100,55 55 100,45 55 100,45 45 100))
> It gives you the expected output.
> I would guess it is the java function you are using that is faulty (the
> geometrycollection constructer).
> Cheers,
> Rémi-C
> 2013/12/18 Baris Ergun <barisergun75 at gmail.com>
>> Hello
>> I create a GeometryCollection as below
>> GeometryCollection coll = new GeometryCollection(
>>                             "SRID=-1;GEOMETRYCOLLECTIONM(POINTM(10 10
>> 100),LINESTRINGM(0 50 100, 100 50 100),POLYGONM((25 25 100,75 25 100,75 75
>> 100,25 75 100,25 25 100),(45 45 100,55 45 100,55 55 100,45 55 100,45 45
>> 100)))"));
>> when I reprint the coll.toString() I see that my geom string is changed
>> to below :
>> "SRID=-1;GEOMETRYCOLLECTIONM(POINT(10 10 100),LINESTRING(0 50 100, 100 50
>> 100),POLYGON((25 25 100,75 25 100,75 75 100,25 75 100,25 25 100),(45 45
>> 100,55 45 100,55 55 100,45 55 100,45 45 100)))"
>> As you can see GEOMETRYCOLLECTIONM is preserved but POINTM LINESTRINGM
>> and POLYGONM is changed to POINT LINESTRING and POLYGON . And because of
>> this I get cannot mix dimensionality when I am trying to insert this geom
>> to database.
>> I have tried this with postgis jdbc driver 1.1.5; 1.3.3 and 2.0.1
>> versions.
>> This is a test written in datanucleus orm for geospatial extensions and
>> the test is run against the below table (create script) in postgresql db.
>> CREATE TABLE public.samplepggeometrycollectionm
>>   samplepggeometrycollectionm_id integer NOT NULL DEFAULT
>> nextval('samplepggeometrycollectionm_samplepggeometrycollectionm_id_seq'::regclass),
>>   geom geometry(GeometryCollectionM),
>>   id bigint NOT NULL,
>>   name character varying(255),
>>   CONSTRAINT samplepggeometrycollectionm_pkey PRIMARY KEY
>> (samplepggeometrycollectionm_id)
>> WITH (
>>   OIDS=FALSE
>> ALTER TABLE public.samplepggeometrycollectionm
>>   OWNER TO postgres;
>> Awaiting ur suggestions.
>>  Baris
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Barış
www.linkedin.com/in/barisergun
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131218/b46425f2/attachment.html>
