[postgis-users] import .ecw into postgis database ?
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Tue Feb 26 11:21:13 PST 2013
First you have to make sure GDAL reads .ecw files properly. It is a GDAL problem. Then you might see if raster2pgsql is able to read and import the files in PostGIS. This will be a PostGIS problem but you're not there yet.
Pierre
> -----Original Message-----
> From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-
> bounces at lists.osgeo.org] On Behalf Of laurent
> Sent: Tuesday, February 26, 2013 11:50 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] import .ecw into postgis database ?
> Hello,
> I'm working on windows 7 64bits.
> I would like import into my db several .ecw files. Up to now i have followed
> this following tutorial :
> http://trac.osgeo.org/osgeo4w/wiki/pkg-gdal-ecw
> I have installed the ECW SDK and paste the *dll from
> redistributable\vc90\win32\ to C:\Windows\SysWOW64.
> But it does not work...What is the next step? I am on the right path?
> Thank you to throw light for me.
> Kind regards.
> View this message in context: http://postgis.17.n6.nabble.com/import-ecw-
> into-postgis-database-tp5002697.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
