[postgis-users] [GENERAL] Query with LIMIT but as random result set?
Stefan Keller
sfkeller at gmail.com
Thu Jan 10 14:36:38 PST 2013
Hi Kevin
No; I'm thinking about some query (or function) that selects random
points (POIs) with certain characteristics like decreasing density. I
didn't find much theory about how to *create* such random points.
There seems to be more literature and implementation about measuring
geographic distribution (like in ArcGIS http://bit.ly/13lTFj9 ).
Under "radial distribution function" I understand a function which
describes how density varies depending on the distance from a
reference point (= the user).
Yours, Stefan
2013/1/10 Kevin Grittner <kgrittn at mail.com>:
> Stefan Keller wrote:
>> "... ORDER BY random() LIMIT 10;" works ok.
>> But with the following option it gets more tricky assume:
>>> And as an option the (limited) resultset should be spatially
>>> distributed (not clustered).
>> I'm thinking about some radial spatial distribution function.
> So, you explicitly *don't* want a random selection? By "spatially
> distributed" you mean that if you have already chosen one
> particular location, other locations which are close to it should
> be less probable (or impossible) to include in the limited result
> set? How would you define the desired result? The one with the
> highest best solution to the "traveling salesman" problem?
> -Kevin
