[postgis-users] pgbench
Donovan Cameron
sault.don at gmail.com
Mon Jan 21 14:37:59 PST 2013
I checked, and it looks like it is part of the postgresql-contrib
package for your system (Ubuntu 10.04 - Lucid).
You can verify that in the list of programs/functions that come with
that package at
http://packages.ubuntu.com/lucid/postgresql-contrib-8.4
In case your wondering, on those pages I've linked too, if you have to
get in touch with the package maintainers for more info, their emails
are below the "Maintainer: " portion on the right tab/menu of the
page.
On Mon, Jan 21, 2013 at 3:32 PM, Donovan Cameron <sault.don at gmail.com> wrote:
> Hey José,
> The details on the postgresql-contrib packages are here:
> http://packages.ubuntu.com/lucid/database/postgresql-contrib
> You should be able to install it on Ubuntu 10.04 with: apt-get install
> postgresql-contrib
> After that is installed, open a terminal and type: pgbench --version
> That should output: pgbench (PostgreSQL) 9.1.x
> If it throws an error, chances are it's not in the postgresql-contrib
> package and you will have better luck getting in touch with the
> package maintainers and submitting an "enhancement" request so that
> pgbench is included in postgresql-contrib.
> On Thu, Jan 17, 2013 at 1:14 AM, José María <jmamuedo at gmail.com> wrote:
>> Thanks Donovan!!
>> I got information about alloptions of pgbench, but I didn found information
>> about how can install this tool.
>> I have installed postgresql9.1 and postgis 2.0 in a ubuntu 10.04 linux
>> machine.
>> But the question is that I don't know how can install pgbench. I did "locate
>> contrib" and this was the result:
>> /usr/share/doc/postgresql-contrib-9.1
>> /usr/share/doc/postgresql-contrib-9.1/autoinc.example
>> /usr/share/doc/postgresql-contrib-9.1/changelog.Debian.gz
>> /usr/share/doc/postgresql-contrib-9.1/copyright
>> /usr/share/doc/postgresql-contrib-9.1/insert_username.example
>> /usr/share/doc/postgresql-contrib-9.1/moddatetime.example
>> /usr/share/doc/postgresql-contrib-9.1/refint.example
>> /usr/share/doc/postgresql-contrib-9.1/timetravel.example
>> /var/cache/apt/archives/postgresql-contrib-9.1_9.1.7-0ubuntu12.04_i386.deb
>> /var/lib/dpkg/info/postgresql-contrib-9.1.list
>> /var/lib/dpkg/info/postgresql-contrib-9.1.md5sums
>> /var/lib/dpkg/info/postgresql-contrib-9.1.postinst
>> /var/lib/dpkg/info/postgresql-contrib-9.1.prerm
>> Donovan, Could you help me with this? What do I have to do?
>> Thanks!!
>> José María
>> 2013/1/16 Donovan Cameron <sault.don at gmail.com>
>>> Hey Jose,
>>> At least on linux, it's part of the postgresql-contrib package and can
>>> be accessed via CLI.
>>> Usage:
>>> pgbench [OPTIONS]... [DBNAME]
>>> Initialization options:
>>> -i invokes initialization mode
>>> -F NUM fill factor
>>> -s NUM scaling factor
>>> Benchmarking options:
>>> -c NUM number of concurrent database clients (default: 1)
>>> -C establish new connection for each transaction
>>> -D VARNAME=VALUE
>>> define variable for use by custom script
>>> -f FILENAME read transaction script from FILENAME
>>> -j NUM number of threads (default: 1)
>>> -l write transaction times to log file
>>> -M {simple|extended|prepared}
>>> protocol for submitting queries to server (default: simple)
>>> -n do not run VACUUM before tests
>>> -N do not update tables "pgbench_tellers" and
>>> "pgbench_branches"
>>> -r report average latency per command
>>> -s NUM report this scale factor in output
>>> -S perform SELECT-only transactions
>>> -t NUM number of transactions each client runs (default: 10)
>>> -T NUM duration of benchmark test in seconds
>>> -v vacuum all four standard tables before tests
>>> Common options:
>>> -d print debugging output
>>> -h HOSTNAME database server host or socket directory
>>> -p PORT database server port number
>>> -U USERNAME connect as specified database user
>>> --help show this help, then exit
>>> --version output version information, then exit
>>> Report bugs to <pgsql-bugs at postgresql.org>
>>> If you let the mailing list know what operating system your using for
>>> postgresql then you'll probably get a better answer.
>>> Donovan
>>> On Wed, Jan 16, 2013 at 8:23 AM, José María <jmamuedo at gmail.com> wrote:
>>> > Help!!
>>> > I need use pgbench but I don't know how to install and use this tool!!
>>> > Any idea?
>>> > Thanks
>>> > _______________________________________________
>>> > postgis-users mailing list
>>> > postgis-users at lists.osgeo.org
>>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
