[postgis-users] Trying to restore a .backup file
Gunnar Oehmichen
oehm8895 at uni-landau.de
Mon Jun 24 08:05:32 PDT 2013
Dear Participants,
As part of my thesis (environmental sciences) I recently started working
with PostgreSQL (newbie here). The georeferenced database has been
transferred from a local Windows7 desktop machine to me.
I am using Ubuntu 12.04 64 bit with Xubuntu as a Desktop-environment
Postgres Version 9.1.9, Postgis 2.0.1.2, PGAdminIII as GUI.
To restore the .backup file I built a new Database "MI" in the GUI
without using any template from the definitions tab:
/usr/bin/pg_restore --host localhost --port 5432 --username "postgres"
--dbname "MI" --no-password --verbose
"/home/gunnaroeh/Dokumente/Laenderdaten/Database/LaenderStand_02-20.backup"
pg_restore: connecting to database for restore
pg_restore: creating TABLE mzb
pg_restore: creating TABLE samplsites_mzb
pg_restore: [archiver (db)] Error while PROCESSING TOC:
pg_restore: [archiver (db)] Error from TOC entry 200; 1259 51728 TABLE
samplsites_mzb postgres
pg_restore: [archiver (db)] could not execute query: ERROR: type
"geometry" does not exist
LINE 14: east_north geometry(Point,31467)
Command was: CREATE TABLE samplsites_mzb (
land character varying(50),
samplsite_id integer NOT NULL,
samplsite character var...
pg_restore: [archiver (db)] could not execute query: ERROR: relation
"public.samplsites_mzb" does not exist
Command was: ALTER TABLE public.samplsites_mzb OWNER TO postgres;
pg_restore: creating TABLE samplsites_phch
pg_restore: restoring data for table "mzb"
pg_restore: restoring data for table "samplsites_mzb"
pg_restore: [archiver (db)] Error from TOC entry 3147; 0 51728 TABLE
DATA samplsites_mzb postgres
"samplsites_mzb" does not exist
Command was: COPY samplsites_mzb (land, samplsite_id, samplsite,
samplsite_name, rechtswert, hochwert, easting, northing, latitude, longi...
pg_restore: restoring data for table "samplsites_phch"
pg_restore: creating CONSTRAINT id
pg_restore: [archiver (db)] Error from TOC entry 3145; 2606 59403
CONSTRAINT id postgres
Command was: ALTER TABLE ONLY samplsites_mzb
ADD CONSTRAINT id PRIMARY KEY (samplsite_id);
pg_restore: setting owner and privileges for TABLE mzb
pg_restore: setting owner and privileges for TABLE samplsites_mzb
pg_restore: setting owner and privileges for TABLE samplsites_phch
pg_restore: setting owner and privileges for TABLE DATA mzb
pg_restore: setting owner and privileges for TABLE DATA samplsites_mzb
pg_restore: setting owner and privileges for TABLE DATA samplsites_phch
pg_restore: setting owner and privileges for CONSTRAINT id
WARNING: errors ignored on restore: 4
Prozess beendete mit Exitcode 1.
If I add the extensions "postgis" and "postgis_topology" to the new db
"MI" at least the following lines are missing from the messages:
"geometry" does not exist.
Also noteworthy:
postgres=# SELECT PostGIS_version();
ERROR: function postgis_version() does not exist
LINE 1: SELECT PostGIS_version();
HINT: No function matches the given name and argument types. You might
need to add explicit type casts.
By the way, the template postgis is not available in the definitions-tab
using the GUI.
I am also posting to this list as I do not know, wether the problem is
postgis related or not,
Thank you very much,
Gunnar
