[postgis-users] postgis-users Digest, Vol 136, Issue 18
Humberto Cereser Ibanez humberto at pastoraldacrianca.org.br
Tue Jun 25 06:14:37 PDT 2013
Hi Ketty,
I found at my Debian Squeeze box the following SQL script, but I never
launched it:
/usr/share/postgresql/9.1/contrib/postgis-1.5/uninstall_postgis.sql
best regards,
Em Ter, 2013-06-25 às 15:33 +0300, Ketty Adoch escreveu:
> Hi all,
> How do i completely uninstall postgis-1.5.3 from ubuntu 12.04 on
> postgresql-9.1
> Running sudo apt-get remove postgis and sudo apt-get purge postgis
> does not uninstall postgis
> Then checking for version of postgis "SELECT postgis_full_version()"
> still returns postgis-1.5.3 as the running version.
> Any pointers?
> regards,
> Ketty
> Ketty Adoch
> Skype id: adockatie
> Twitter: www.twitter.com/kadoch
> On Mon, Jun 24, 2013 at 10:00 PM,
> <postgis-users-request at lists.osgeo.org> wrote:
>         Send postgis-users mailing list submissions to
>                 postgis-users at lists.osgeo.org
>         To subscribe or unsubscribe via the World Wide Web, visit
>         http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>         or, via email, send a message with subject or body 'help' to
>         You can reach the person managing the list at
>                 postgis-users-owner at lists.osgeo.org
>         When replying, please edit your Subject line so it is more
>         specific
>         than "Re: Contents of postgis-users digest..."
>         Today's Topics:
>            1. Re: Raster pixel count too high (Hugues Fran?ois)
>            2. Re: Raster pixel count too high (Kim Bisgaard)
>            3. Trying to restore a .backup file (Gunnar Oehmichen)
>            4. Re: Trying to restore a .backup file (Humberto Cereser
>         Ibanez)
>            5. Re: Raster pixel count too high (Andreas For? Tollefsen)
>         Message: 1
>         Date: Sun, 23 Jun 2013 21:52:59 +0200
>         From: Hugues Fran?ois <hugues.francois at irstea.fr>
>         To: "PostGIS Users Discussion" <postgis-users at lists.osgeo.org>
>         Subject: Re: [postgis-users] Raster pixel count too high
>         Message-ID:
>         <3CB901080554B04881D30F111F62D93002CE0A1A at nadia.grenoble.cemagref.fr>
>         Content-Type: text/plain; charset="iso-8859-1"
>         Hello,
>         I have a lot of work and I won't be able to test your data
>         now, but I'll try ASAP.
>         On my side, I have to deal with rasters dem tiles which
>         overlap each other. I need to have unique tiles and I made the
>         two attached functions to achieve that :
>         1. The first one, makegrid, simply builds a grid given a
>         bounding box geometry and height / width
>         2. The second, unique_tiles, calls the first one to make a
>         whole raster made of regular tiles of the wanted size in
>         number of pixels from a raster table of aligned tiles (it
>         finds its bounding box and use it to makegrid from left bottom
>         corner using original pixel height and width and then use this
>         grid to clip raster)
>         Maybe they can help you in your clipping process. You may
>         improve performance if you remove the st_union in unique_tiles
>         (needed if your raster is made of multiple tiles).
>         Hugues.
>         De : postgis-users-bounces at lists.osgeo.org
>         [mailto:postgis-users-bounces at lists.osgeo.org] De la part de
>         Envoy? : dimanche 23 juin 2013 10:47
>         ? : PostGIS Users Discussion
>         Objet : Re: [postgis-users] Raster pixel count too high
>         Thanks for your answers.
>         First to Hugues. I do not think they are perfectly aligned.
>         The raster we have imported seems to start just west of -180.
>         Hence, it is not within the limits of SRID 4326. We have to
>         modify it a little.
>         What I do find strange is that ArcGIS counts 3600 which is the
>         expected pixel count. So why these two functions count so
>         differently on the exact same data is weird.
>         Try yourself with one of the Nightlights data:
>         http://www.ngdc.noaa.gov/eog/dmsp/downloadV4composites.html
>         <http://www.ngdc.noaa.gov/eog/dmsp/downloadV4composites.html>
>          and our vector grid shapefile available here:
>         http://www.prio.no/Data/PRIO-GRID/
>         <http://www.prio.no/Data/PRIO-GRID/>
>         Kim: We do not directly use ST_Intersection in our script, but
>         ST_Clip to clip the raster according to our polygons, and only
>         where they ST_Intersects(), not ST_Intersection();
>         I still do not understand your suggestion.
>         Best,
>         Andreas
>         2013/6/18 Kim Bisgaard <kib at dmi.dk <mailto:kib at dmi.dk> >
>         Hi,
>         Because ST_Intersection() returns neighbour pixels sharing a
>         same value as only one
>          polygon. You thus get a bigger area and thus more points.
>         Bit me once :-/
>         Regards,
>         Kim
>         On 2013-06-18 14:59, Andreas For? Tollefsen wrote:
>                 Hi Kim,
>                 Thanks for your answer. However, we want raster as an
>         output, since we want to be able to use the summarystats
>         function.
>                 Please elaborate how you think ST_PixelAsPolygons
>         should solve out issue?
>                 Thanks.
>                 Andreas
>                 Hi,
>                 Try to use 'ST_PixelAsPolygons(ST_Clip(n.rast,
>         p.cell))'
>                 instead of 'ST_Intersects(n.rast, p.cell)'
>                 Regards,
>                 Kim
>                 On 2013-06-18 11:03, Andreas For? Tollefsen wrote:
>                         Hi,
>                         We are working on a raster summarystats script
>         to calculate various statistics for the pixels within fishnet
>         polygons.
>                         Our raster cell size is 0.0083333333333... x
>         0.0083333333333... degrees while our quadrat polygons are 0.5
>         x 0.5 decimal degrees.
>                         This should give us 60x60 raster pixels within
>         each of our polygons. ArcGIS zonal statistics returns a pixel
>         count of 3600 in addition to other statistics.
>                         However, PostGIS returns 3721 pixel count.
>                         We do not really understand why, but it seems
>         that our query includes some pixels that are outside of the
>         polygon, but still touches the vertices of the polygon and are
>         therefore included in the calculation.
>                         Are there any way of modifying our script to
>         return the same result as ArcGIS?
>                         Thanks!
>                         Andreas
>                         script:
>                         /* This query makes one raster for each
>         PRIO-GRID cell. Clip and union is the procedure. */
>                         INSERT INTO nightlightsprio (gid, "year",
>         rast)
>                         (SELECT gid, "year", ST_Union(raster) as rast
>                         FROM
>                         (SELECT p.gid, n."year", ST_Clip(n.rast,
>         p.cell) as raster
>                         FROM nightlights n, priogridyear p
>                         WHERE ST_Intersects(n.rast, p.cell)
>                         AND n."year" = p."year"
>                         as priorast
>                         GROUP BY gid, "year");
>                         /* Default BandNoDataValue is 0. Raster value
>         0 means no light, not no data. Setting to NULL. This produces
>         correct results. */
>                         UPDATE nightlightsprio2 SET rast =
>         ST_SetBandNoDataValue(rast, 1, NULL);
>                         ALTER TABLE nightlightsprio2 ADD COLUMN
>         nightlights_sum double precision,
>                         ADD COLUMN nightlights_mean double precision,
>                         ADD COLUMN nightlights_sd double precision,
>                         ADD COLUMN nightlights_min double precision,
>                         ADD COLUMN nightlights_max double precision,
>                         ADD COLUMN nightlights_count integer;
>                         UPDATE nightlightsprio2 SET nightlights_sum =
>         (ST_SummaryStats(rast)).sum;
>                         UPDATE nightlightsprio2 SET nightlights_mean =
>         (ST_SummaryStats(rast)).mean;
>                         UPDATE nightlightsprio2 SET nightlights_sd =
>         (ST_SummaryStats(rast)).stddev;
>                         UPDATE nightlightsprio2 SET nightlights_min =
>         (ST_SummaryStats(rast)).min;
>                         UPDATE nightlightsprio2 SET nightlights_max =
>         (ST_SummaryStats(rast)).max;
>                         UPDATE nightlightsprio2 SET nightlights_count
>         = (ST_SummaryStats(rast)).count;
>         _______________________________________________
>         <mailto:postgis-users at lists.osgeo.org>
>         <http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users>
>                 Kim Bisgaard
>                 Application Development Division     Phone: +45 3915
>         7562 <tel:%2B45%203915%207562>  (direct)
>                 Danish Meteorological Institute      Fax: +45 3915
>         7460 <tel:%2B45%203915%207460>  (division)
>         Kim Bisgaard
>         Application Development Division     Phone: +45 3915 7562
>         Danish Meteorological Institute      Fax: +45 3915 7460 <tel:%
>         -------------- next part --------------
>         A non-text attachment was scrubbed...
>         Type: application/octet-stream
>         Desc: function_makegrid.sql
>         URL:
>         <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130623/d7bb420a/attachment-0002.obj>
>         Desc: function_unique_tiles.sql
>         URL:
>         <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130623/d7bb420a/attachment-0003.obj>
>         Message: 2
>         Date: Mon, 24 Jun 2013 11:30:39 +0000
>         From: Kim Bisgaard <kib at dmi.dk>
>         To: "postgis-users at lists.osgeo.org"
>         Message-ID: <51C82DDF.8070007 at dmi.dk>
>         Hi,
>         You are right, I mistook ST_intersects() for ST_intersection()
>         - me butting out of this thread..
>         Regards,
>         Kim
>         Best,
>         Andreas
>         2013/6/18 Kim Bisgaard <kib at dmi.dk<mailto:kib at dmi.dk>>
>         Hi,
>         Bit me once :-/
>         Regards,
>         Kim
>         Hi Kim,
>         Thanks for your answer. However, we want raster as an output,
>         since we want to be able to use the summarystats function.
>         Please elaborate how you think ST_PixelAsPolygons should solve
>         out issue?
>         Thanks.
>         Andreas
>         Hi,
>         Try to use 'ST_PixelAsPolygons(ST_Clip(n.rast, p.cell))'
>         Regards,
>         Kim
>         Hi,
>         We are working on a raster summarystats script to calculate
>         various statistics for the pixels within fishnet polygons.
>         This should give us 60x60 raster pixels within each of our
>         polygons. ArcGIS zonal statistics returns a pixel count of
>         We do not really understand why, but it seems that our query
>         includes some pixels that are outside of the polygon, but
>         still touches the vertices of the polygon and are therefore
>         Are there any way of modifying our script to return the same
>         result as ArcGIS?
>         Thanks!
>         Andreas
>         script:
>         /* This query makes one raster for each PRIO-GRID cell. Clip
>         INSERT INTO nightlightsprio (gid, "year", rast)
>         FROM
>         (SELECT p.gid, n."year", ST_Clip(n.rast, p.cell) as raster
>         as priorast
>         /* Default BandNoDataValue is 0. Raster value 0 means no
>         light, not no data. Setting to NULL. This produces correct
>         results. */
>         UPDATE nightlightsprio2 SET rast = ST_SetBandNoDataValue(rast,
>         1, NULL);
>         ALTER TABLE nightlightsprio2 ADD COLUMN nightlights_sum double
>         precision,
>         UPDATE nightlightsprio2 SET nightlights_count =
>         postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
>         Kim Bisgaard
>         Application Development Division     Phone: +45 3915 7562<tel:
>         Danish Meteorological Institute      Fax: +45 3915 7460<tel:%
>         Kim Bisgaard
>         Kim Bisgaard
>         (direct)
>         (division)
>         An HTML attachment was scrubbed...
>         URL:
>         <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130624/87c77d58/attachment-0001.html>
>         Message: 3
>         Date: Mon, 24 Jun 2013 17:05:32 +0200
>         From: Gunnar Oehmichen <oehm8895 at uni-landau.de>
>         To: postgis-users at lists.osgeo.org
>         Subject: [postgis-users] Trying to restore a .backup file
>         Message-ID: <51C8603C.5080101 at uni-landau.de>
>         Content-Type: text/plain; charset=ISO-8859-15; format=flowed
>         Dear Participants,
>         As part of my thesis (environmental sciences) I recently
>         started working
>         with PostgreSQL (newbie here). The georeferenced database has
>         been
>         transferred from a local Windows7 desktop machine to me.
>         I am using Ubuntu 12.04 64 bit with Xubuntu as a
>         Desktop-environment
>         Postgres Version 9.1.9, Postgis 2.0.1.2, PGAdminIII as GUI.
>         To restore the .backup file I built a new Database "MI" in the
>         GUI
>         without using any template from the definitions tab:
>         /usr/bin/pg_restore --host localhost --port 5432 --username
>         "postgres"
>         --dbname "MI" --no-password  --verbose
>         "/home/gunnaroeh/Dokumente/Laenderdaten/Database/LaenderStand_02-20.backup"
>         pg_restore: connecting to database for restore
>         pg_restore: creating TABLE mzb
>         pg_restore: creating TABLE samplsites_mzb
>         pg_restore: [archiver (db)] Error while PROCESSING TOC:
>         pg_restore: [archiver (db)] Error from TOC entry 200; 1259
>         51728 TABLE
>         samplsites_mzb postgres
>         pg_restore: [archiver (db)] could not execute query: ERROR:
>          type
>         "geometry" does not exist
>         LINE 14:     east_north geometry(Point,31467)
>              Command was: CREATE TABLE samplsites_mzb (
>              land character varying(50),
>              samplsite_id integer NOT NULL,
>              samplsite character var...
>          relation
>         "public.samplsites_mzb" does not exist
>              Command was: ALTER TABLE public.samplsites_mzb OWNER TO
>         postgres;
>         pg_restore: creating TABLE samplsites_phch
>         pg_restore: restoring data for table "mzb"
>         pg_restore: restoring data for table "samplsites_mzb"
>         pg_restore: [archiver (db)] Error from TOC entry 3147; 0 51728
>         TABLE
>         DATA samplsites_mzb postgres
>          relation
>         "samplsites_mzb" does not exist
>              Command was: COPY samplsites_mzb (land, samplsite_id,
>         samplsite,
>         samplsite_name, rechtswert, hochwert, easting, northing,
>         latitude, longi...
>         pg_restore: restoring data for table "samplsites_phch"
>         pg_restore: creating CONSTRAINT id
>         pg_restore: [archiver (db)] Error from TOC entry 3145; 2606
>         59403
>         CONSTRAINT id postgres
>          relation
>              Command was: ALTER TABLE ONLY samplsites_mzb
>              ADD CONSTRAINT id PRIMARY KEY (samplsite_id);
>         pg_restore: setting owner and privileges for TABLE mzb
>         samplsites_mzb
>         samplsites_phch
>         pg_restore: setting owner and privileges for TABLE DATA mzb
>         samplsites_mzb
>         samplsites_phch
>         pg_restore: setting owner and privileges for CONSTRAINT id
>         WARNING: errors ignored on restore: 4
>         Prozess beendete mit Exitcode 1.
>         If I add the extensions "postgis" and "postgis_topology" to
>         the new db
>         "MI" at least the following lines are missing from the
>         messages:
>          type
>         "geometry" does not exist.
>         Also noteworthy:
>         postgres=# SELECT PostGIS_version();
>         ERROR:  function postgis_version() does not exist
>         LINE 1: SELECT PostGIS_version();
>         HINT:  No function matches the given name and argument types.
>         You might
>         need to add explicit type casts.
>         By the way, the template postgis is not available in the
>         definitions-tab
>         using the GUI.
>         I am also posting to this list as I do not know, wether the
>         problem is
>         postgis related or not,
>         Thank you very much,
>         Gunnar
>         Message: 4
>         Date: Mon, 24 Jun 2013 14:10:14 -0300
>         From: Humberto Cereser Ibanez
>         <humberto at pastoraldacrianca.org.br>
>         To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
>         Subject: Re: [postgis-users] Trying to restore a .backup file
>         Message-ID: <1372093814.2842.35.camel at p210>
>         Content-Type: text/plain; charset="UTF-8"
>         Dear Gunnar,
>         I suggest to you recreate your MI database, add spatial
>         extensions and
>         restore your backup:
>         1) drop MI database (dropdb) and create it from scratch
>         (createdb)
>         2) execute the steps that are showed in "2.6 Creating a
>         spatial database
>         using EXTENSIONS" at
>         http://postgis.net/docs/manual-2.0/postgis_installation.html#create_new_db_extensions , and
>         3) run your pg_restore
>         Best regards,
>         Em Seg, 2013-06-24 ?s 17:05 +0200, Gunnar Oehmichen escreveu:
>         > Dear Participants,
>         started working
>         has been
>         Desktop-environment
>         the GUI
>         "postgres"
>         51728 TABLE
>          type
>          relation
>         postgres;
>         51728 TABLE
>          relation
>         samplsite,
>         latitude, longi...
>         59403
>          relation
>         samplsites_mzb
>         samplsites_phch
>         samplsites_mzb
>         samplsites_phch
>         the new db
>         messages:
>          type
>         > Also noteworthy:
>         types. You might
>         definitions-tab
>         > using the GUI.
>         problem is
>         > Gunnar
>         Message: 5
>         Date: Mon, 24 Jun 2013 20:18:46 +0200
>         From: Andreas For? Tollefsen <andreasft at gmail.com>
>         Message-ID:
>                 <CAGMz7DkGgc6-t_-LSX
>         +mC6cviUb2HQnqP0bZGOahXAgqBeiSKw at mail.gmail.com>
>         Ok. I was worried there was something genious about your
>         suggestion that I
>         could not grasp :)
>         Andreas
>         2013/6/24 Kim Bisgaard <kib at dmi.dk>
>         >  Hi,
>         ST_intersection() - me
>         > Regards,
>         > Kim
>         but ST_Clip to
>         > clip the raster according to our polygons, and only where
>         they
>         >  Best,
>         > Andreas
>         > 2013/6/18 Kim Bisgaard <kib at dmi.dk>
>         >> Hi,
>         a same value
>         >> as only one
>         >> Bit me once :-/
>         >> Regards,
>         >> Kim
>         >> Hi Kim,
>         output, since we
>         solve out issue?
>         >> Thanks.
>         >>  Andreas
>         >>> Hi,
>         >>> Regards,
>         >>> Kim
>         >>>  Hi,
>         calculate various
>         0.0083333333333...
>         >>> degrees while our quadrat polygons are 0.5 x 0.5 decimal
>         degrees.
>         polygons.
>         >>> ArcGIS zonal statistics returns a pixel count of 3600 in
>         addition to other
>         >>> statistics.
>         query includes
>         >>> some pixels that are outside of the polygon, but still
>         >>> of the polygon and are therefore included in the
>         calculation.
>         same result as
>         >>> ArcGIS?
>         >>> Thanks!
>         >>>  Andreas
>         >>>  script:
>         Clip and union
>         >>> FROM
>         >>> as priorast
>         light, not no
>         >>> data. Setting to NULL. This produces correct results. */
>         double
>         >>> precision,
>         listpostgis-users at lists.osgeo.orghttp://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>         >>> Kim Bisgaard
>         (direct)
>         (division)
>         >> Kim Bisgaard
>         (direct)
>         (division)
>         > Kim Bisgaard
>         (direct)
>         (division)
>         URL:
>         <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130624/3ef358ba/attachment-0001.html>
>         End of postgis-users Digest, Vol 136, Issue 18
