[postgis-users] [Raster] MNT 250 IGNF data import problem
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Tue Oct 22 07:51:37 PDT 2013
You loaded specifying -b 1 so it's not surprising it complains when you try to display stats about band 2 and 3... You have only one band in the db...
> -----Original Message-----
> From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-
> bounces at lists.osgeo.org] On Behalf Of Yves Jacolin
> Sent: Tuesday, October 22, 2013 7:48 AM
> To: PostGIS Users Discussion
> Subject: [postgis-users] [Raster] MNT 250 IGNF data import problem
> Hello list,
> I am currently trying importing french IGN MNT 250 into a postgis database
> (v
> 2.0.1):
> raster2pgsql -b 1 -s 2154 -I -C -t 100x100 MNT250_L93_FRANCE.ASC
> raster.mnt250
> | psql -d formation
> When testing my raster layer I get strange result:
> SELECT rid, band, (stats).*
> FROM (SELECT rid, band, ST_SummaryStats(rast, band) As stats
> FROM raster.mnt250 CROSS JOIN generate_series(1,3) As band
> WHERE rid=2) As foo;
> NOTICE: Invalid band index (must use 1-based). Returning NULL
> CONTEXT: SQL function "st_summarystats" statement 1
> [several time]
> rid | band | count | sum | mean | stddev | min | max
> 2 | 1 | 10000 | 0 | 0 | 0 | 0 | 0
> 2 | 2 | | | | | |
> 2 | 3 | | | | | |
> QGIS can't display my layer (well the layer seems white) and if I request my
> layer I get some weird value (224964728 for example).
> In QGIS log, I have:
> ERROR 1: PG: dbname=formation host=localhost user=yjacolin password=
> port=5432
> mode=2 schema=raster table=mnt250, band 1: IReadBlock failed at X offset
> 32, Y
> offset 29
> ERROR 1: Error retrieving raster data from database
> Any idea why this is not working as expected?
> When I use raster2pgsql I get this message:
> raster2pgsql: /usr/local/lib/libgdal.so.1: no version information available
> (required by raster2pgsql)
> I built gdal but not postgis.
> Thanks,
> Y.
> Responsable Formation et Support
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel (France) : +33 4 79 26 57 98
> Tel (Suisse) : 021 619 10 43 (new)
> Mob. : +33 6 18 75 42 21
> Fax : 04 79 70 15 81
> Mail : yves.jacolin at camptocamp.com
> http://www.camptocamp.com
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
