[postgis-users] [Raster] MNT 250 IGNF data import problem
Yves Jacolin yves.jacolin at camptocamp.com
Tue Oct 22 08:58:02 PDT 2013
Hello,
Yes it uses 32BUI (as far I can remember). I will check tomorrow and
made more test.
Thanks,
Y.
2013/10/22 Pierre Racine <Pierre.Racine at sbf.ulaval.ca>:
>> Because I did a quick test and copied past previous SQL requests and I did
>> not
>> clean it before! Of course you can remove the next 2 bands which don't
>> exist
>> but the first one should have correct statistic.
>> Thanks Pierre to let me know the logical ;)
> Sorry I thought you were complaining about the error message not about the stats....
> MNT250_L93_FRANCE.ASC is a text file right? I would suspect a bad interpretation of the decimal separator.
> Check also what pixeltype was used by the importer with ST_BandPixelType() or ST_BandMetadata(). I suspect it used 32BUI (because it does not recognize the separator) when it should use 32BF.
> Pierre
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Responsable Formation et Support
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel (France) : +33 4 79 26 57 98
Tel (Suisse) : 021 619 10 43
Mob. : +33 6 18 75 42 21
Fax : 04 79 70 15 81
Mail : yves.jacolin at camptocamp.com
http://www.camptocamp.com
